Forum Home › Forums › Communicating with Devices › Modbus › Commands in Modbus
- This topic has 14 replies, 4 voices, and was last updated 9 years, 5 months ago by
August 5, 2016 at 6:27 am #1510
Praveen
I need to send commands to my PLC using Modbus from SCADA communicator.
I am using KpModBus_Adam6015.xml as a device template. At the end of the template, I could see few commands. But in SCADA communicator, No commands is showing. I also enabled commands in communicator.
Can you please give more details for sending modbus commands?
August 5, 2016 at 11:55 am #1511
Go to Commands tab in Communicator and send a command with a number specified in the template. You should see the command in communication line log and in Device Data tab.
If it works, configure output channels, bind them to a scheme or a table view and send via the web app.
August 5, 2016 at 3:46 pm #1512Praveen
In commands tab of communicator, I could see only entry for password (Not sure what password it is.)
Screenshot is at: https://postimg.org/image/xec0xteb5/
Can you please let me now if I am missing anything and give more details on modbus commands.
August 5, 2016 at 5:44 pm #1513
MikhailModeratorThe default password is 12345. Try to enter it and look 🙂
August 8, 2016 at 7:09 am #1517Praveen
Thank you for the information :-).
I am able to send commands now.
With B/R,
Praveen.BMay 28, 2017 at 8:13 am #2186
minhrapidParticipantthe Data from modbus and comuncator different. I can not understand, who can help me?
May 29, 2017 at 4:47 am #2191
http://i.imgur.com/BgfdPQJ.png
http://i.imgur.com/VdxozjQ.pngMay 29, 2017 at 9:04 am #2200MarCus0
ParticipantHi
Check please Your template where You define addresses conversion from Modbus table to Communicator Chanel’s.
Regards
MarekMay 29, 2017 at 10:42 am #2206
It’s difficult to understand what values are expected in Communicator?May 30, 2017 at 7:55 am #2217
minhrapidParticipantcan you for example?
May 30, 2017 at 10:09 am #2219MarCus0
ParticipantHi
“can you for example?” – You asking me or Mikhail?
Regards
May 30, 2017 at 10:31 am #2221
MikhailModeratorExample:
Expected value of the tag #1 is 10, actual value is 0.May 30, 2017 at 12:38 pm #2224
minhrapidParticipantThank you for the information..MarCusO and Mikhail..
May 31, 2017 at 7:40 am #2229
minhrapidParticipantYou can edit data for me through teamViewer?
May 31, 2017 at 3:00 pm #2232
MikhailModeratorYou can purchase a training and we will solve the issues together via remote connection. Please send an email to get information about the prices.
