MikhailModerator
What kind of tasks do you need to schedule?
For example, there is a time trigger in Automatic Control Module.
MikhailModeratorYes, it’s OK. I haven’t worked with Google Cloud, I used Microsoft Azure. I think they are similar.
Please paste communication line log here.
You should check firewall. Probably, outgoing connection to TCP port 502 is prohibited. Web interface uses port 80 which is usually permitted.
MikhailModeratorSetCulture.exe is a console application. Run it from the command line.
Download the Linux distributive. Then run SetCulture.exe on your Windows computer. It allows to easy switch culture. Set en-GB culture.
Could you provide screenshot of the “SCADA-Administrator has stopped working” error?
MikhailModeratormanjey73, you can switch to English in Administrator settings and then reopen applications.
MikhailModeratorI agree, in the future it’s better to switch language before taking screenshots. But for now, you could open the same forms in English and you will understand what controls and columns are meant.
MikhailModeratorThis is context adv different based on interests of a watcher 🙂
Do you have any questions that we have not clarified yet? Be free to ask
MikhailModeratorAre there any girls in the examples?
MikhailModeratorMistral,
Try to configure Automatic Control Module and publish its screenshots here.
MikhailModeratorNote: the current version of the module includes the deadband option that is close to hysteresis.
MikhailModeratorHi all,
You need Automatic Control Module.
Firstly, make sure that you can successfully send command manually, then use the module to do it automatically.September 25, 2017 at 4:53 pm in reply to: Two opc server running on the same PC. One can get value, Another not value. #2600
It’s strange that ScadaCommMono doesn’t work. This is the same as your demo app.
I think, the possible ways are:
1. If the demo app works, you can tune it and use instead of Communicator.
2. I can try to perform my own recommendations by myself via remote connection. To discuss it, contact me by email info@…By the way, what communication protocols do you use?
When you use http://192.168.0.x/scada in browser address bar, you connect to a web server -
