Forum Home › Forums › Understanding the Software › The problem about ModDBExport module
- This topic has 1 reply, 2 voices, and was last updated 9 years, 1 month ago by
October 8, 2017 at 2:40 pm #2643
zhaochengshen
Participanthi Mikhail:
I have a issue when i use ModDBExport module to export data.Only events data can be export. the current data and archive data can’t export. I have create table “cnldata” and “events”. Why does it happen? How can solve it?here is the detailed log:
ModDBExport.txt
Export Data Module
State: normalData Sources
1. MSSQL – (local); state: normal; in queue cur/arc/ev: 100/0/0; exported cur/arc/ev: 0/0/24; skipped cur/arc/ev: 150/0/0ModDBExport.log
2017-10-08 00:55:13 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:55:18 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:55:23 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:55:28 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:55:29 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:55:33 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:55:38 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:55:43 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:55:48 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:55:53 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:55:58 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:56:03 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:56:08 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:56:13 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:56:18 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:56:23 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:56:28 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:56:29 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:56:33 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:56:38 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:56:43 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:56:48 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:56:53 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 00:56:56 Module ModDBExport is stopped
2017-10-08 00:56:56 Start ModDBExport module
2017-10-08 01:04:38 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 01:04:43 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 01:04:48 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 01:04:53 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 01:04:58 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 01:05:03 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 01:05:08 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 01:05:13 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 01:05:18 Unable to enqueue current data. The maximum size of the queue 100 is exceeded
2017-10-08 01:05:23 Unable to enqueue current data. The maximum size of the queue 100 is exceededOctober 9, 2017 at 6:22 am #2645
Could you make screenshots of the settings of the module?
If you stop the Communicator service and manually send data from Generator of the Server shell, will you get the same errors right after restart?
