Viewing 15 posts - 4,996 through 5,010 (of 6,293 total)
  • in reply to: SQL Export Issues #3284
    Try set “Sending all device data period” to 0 in Communicator.
    in reply to: Get rid of Execute command confirmation windows #3282
    Currently you can’t, but this function is under development now. I hope it will be developed within few months.
    in reply to: Capture Reading at a Certain Time of the Day #3281
    I can use to make a faster sampling to get more accurate energy calculated?
    Data are stored every minute by default. You can change this interval in SCADA-Server settings.
    But formula for a channel of the Real type calculates every time when data are received by Communicator and sent to the Server app.
    From a formula you can’t access historical data. You can save a value to another channel at 6am and then use this channel. Also you can develop or purchase a custom module that implement the required functionality.
    in reply to: BInary commands for Modbus #3280
    This a one possible method.
    Other option is Automatic Control Module that can trigger on simple command and send any custom command.
    in reply to: Unbuntu (Linux) #3273
    On Linux Rapid SCADA works without user interface. You can prepare a configuration on Windows and then copy it to a Linux system. In some cases you can edit XML configuration files manually.
    To control operating, see log files of the apps.
    in reply to: Capture Reading at a Certain Time of the Day #3272
    Do you need to poll a device once a day? If possible, it’s better to poll a device all day in a cycle and get value what you need.
    Channel of the Minute real type calculates its value every minute. For example, if a formula is Val()+1, the channel value is incremented by 1 every minute.
    in reply to: BInary commands for Modbus #3271
    For the row of the output channel in the Administrator app set “Command values” to “Execute” and define a formula for the row. If you just need a constant, a formula can be, for example: 1
    in reply to: Exporting existing data to excel #3267
    Anyway, make a backup before start.
    in reply to: Exporting existing data to excel #3266
    Do I need the chart pro module for this ? Or another ?
    I recommend to try Chart Pro. The trial is free.
    Also you should try Reports -> Minute data report
    See http://demo.rapidscada.net/Reports.aspx
    If I add the new module can I still export data saved before the upgrade ?
    Data format was not changed during the version 5.x.x.x. So you can access the previous data.
    in reply to: Scheme loading failed. Try to reload scheme #3265
    Hi!
    Interesting. What antivirus do you use?
    in reply to: Schema Editor fails to launch #3264
    The Editor opens the default browser. If you change the default browser in the OS, it will open another browser. Also you can copy the address from the IE address bar and paste it in Chrome.
    in reply to: Scheme loading failed. Try to reload scheme #3259
    Try open a scheme and press Ctrl+F5 on problem computers. Also try another browser that is not used before with the old version of the web app.
    in reply to: Schema Editor fails to launch #3257
    IE of any version is not supported. You can use Chrome, Firefox and Edge.
    in reply to: Intergration data input into cloud system #3251
    in reply to: Intergration data input into cloud system #3250
    You should use a device like Moxa Nport that initiates a connection with a cloud server by IP or DNS name. After connection is established, Rapid SCADA server polls the devices.
