Viewing 15 posts - 4,741 through 4,755 (of 6,296 total)
  • in reply to: Numerical display is wrong #4018
    If you have a formula for an input channel, it affects. You didn’t provide a screenshot of the input channel, so I’m not sure.
    in reply to: Responsive Web Design #4008
    How to reproduce the issue on my side?
    in reply to: Numerical display is wrong #4007
    The single digit display cannot be 0.2.4.6~…..
    Ten digits display normal
    I don’t understand the question. Could you explain?
    in reply to: Export to Database Module #4004
    In the Current Data tab you need to enter INSERT request only. Other SQL scripts are needed for creating the database.
    in reply to: Remote commumicator #4001
    rsepulve,
    it would be clear if you provide screenshots of your settings.
    in reply to: Modbus TCP over GPRS (S27x GPRS RTU) #4000
    IP address of a GSM device is specific to a telecommunication company. Sometimes they provide real IP for extra fee. This approach is not flexible. That’s better when a modem connects to a server.
    IP addres I have to put in coomunication settings dor slave devie?
    IP not needed if a modem initiates a connection.
    in reply to: Export to Database Module #3997
    You should provide screenshots of the module settings and log of the export module.
    in reply to: Events not being fired #3996
    Thank you!
    in reply to: Events not being fired #3993
    Wow!
    Could you show the screenshots before and after?
    The above screenshot is too small. I can’t recognize anything.
    in reply to: Export to Database Module #3992
    1. Go to the Modules page
    2. Click the Add (+) button
    3. Add ModDBExport.dll and apply the settings.
    4. Select the module and click the Properties button.
    in reply to: Export to Database Module #3982
    You should create a new database connection in the module properties form and paste SQL requests for this connection.
    What is the particular question?
    in reply to: Events not being fired #3979
    This is a bit strange. On the other hand, I’m sure that the cause exists. Could you provide screenshots of the related input channels?
    in reply to: Minimal modbus system #3978
    Configuration of Rapid SCADA is prepared on Windows, then applied on Linux. I recommend watching the videos to learn how to configure Modbus.
    in reply to: HTTPS on Linux #3975
    I’ve opened an issue on Mono https://github.com/mono/mono/issues/9458
    Hope the Mono team will work on it.
    in reply to: Modbus TCP over GPRS (S27x GPRS RTU) #3974
    Hi Rodrigo,
    Usually a modem is TCP client while Communicator is TCP server. You should set the TCP server type of communication channel in Communicator and allow the incoming connection on Firewall. Setup a modem to connect to the IP or DNS name and TCP port of your server. You will see that a connection is established in a communication line log. If connection is OK, Communicator polls the devices.
    If something goes wrong, provide logs of the communication line.
