Viewing 15 posts - 2,671 through 2,685 (of 6,219 total)
  • in reply to: Connect two pc with RapidGate #9803
    The main PC:
    – Does not need Rapid Gate
    – Has static IP or DNS name
    – No controllers connected
    The “remote” PC:
    – Polls controllers
    – Needs Rapid Gate
    – Can have dynamic IP
    – Rapid Gate initiates connection to the main PC and uploads data automatically
    • This reply was modified 4 years, 3 months ago by Mikhail.
    in reply to: Plot in the future #9792
    Interesting task. Probably, you should use Grafana for this purpose.
    in reply to: ChartPro Quuestion . #9791
    You could create a table view with a limited number of channels to simplify selection. And hide this table view from the explorer tree.
    in reply to: ChartPro Quuestion . #9790
    > This list is to long , can I hide some of the channels from view ?
    Thank you for the screenshot. It’s impossible to hide channels in the current version. We will take this into account in the future.
    > On the same subject I then tried to add a link to a CharPro graph
    Where did you insert a link?
    in reply to: Connect two pc with RapidGate #9788
    Rapid Gate manual is here https://rapidscada.net/doc/content/latest/en/modules/mod-rapid-gate.html
    To get some answers, please ask a specific question.
    in reply to: TCP Api #9775
    in reply to: Plot in the future #9774
    Could you explain the entire task?
    Are the future data mixed with data received from the devices?
    May be you should integrate Rapid SCADA with Grafana to draw charts containing points in the future.
    in reply to: ChartPro Quuestion . #9773
    Could you provide a screenshot containing the inconvenient selection?
    in reply to: Sending On / Off Commands to Modbus Register #9772
    Downloading RAR archives is not secure. Could you demonstrate the existing settings in this thread?
    What type of Modbus register do you need to set: coil or holding register?
    in reply to: BUG: Can’t save SVG image anymore #9767
    Image size is not available because SVG is vector based and can be scaled as needed.
    in reply to: BUG: Can’t save SVG image anymore #9765
    in reply to: BUG: Can’t save SVG image anymore #9764
    I will check and let you know here.
    in reply to: Lag issue on Webstation #9761
    Good that the issue is solved. I recommend to use RAM-drive for storing current data and Communicator logs. Saving on change may cause a lot of HDD/SDD writing and reduce its life.
    > If webstation depends on the data recorded in current data.
    To see new data on a web page:
    1. Data should be written on disk.
    2. Web page should be refreshed.
    So the total time may include the both timeouts.
    We plan to improve this mechanism in the future and receive current data from memory instead of disk.
    in reply to: BUG: Can’t save SVG image anymore #9760
    Could you specify steps to reproduce the issue?
    in reply to: Lag issue on Webstation #9756
    Current data are stored in the file C:\SCADA\ArchiveDAT\Cur\current.dat
    First of all, let’s check that data are changed in this file. To do that, open Administrator – … – Server – Archive – Current Data, then click the View button.
    What would be the result of this check?
    Other question: how many events are generated per day? Events are displayed in the bottom panel of Webstation.
