Forum Home › Forums › Understanding the Software › ChartPro Quuestion .
- This topic has 9 replies, 3 voices, and was last updated 4 years, 9 months ago by
December 16, 2021 at 12:05 pm #9771
Rich Ex
ParticipantHi friends
Quick question about ChartPro .When you select channels to build up a graph is there a way to stop the menu showing every channel for the device . I have a lot of channels that are only for calculations and don’t want the operator to see them …
With the table view you can hide the items , I was hoping for something similar …
RichDecember 16, 2021 at 12:48 pm #9773
Could you provide a screenshot containing the inconvenient selection?
December 16, 2021 at 3:49 pm #9776Rich Ex
ParticipantHi Mikhail
This list is to long , can I hide some of the channels from view ?
RichardDecember 17, 2021 at 6:37 am #9782
manjey73ParticipantI also don’t like such a list, it would be nice to have a configuration file that could be attached to a table or mnemonic of the KP, where to specify what to display in the addendum.
And also use analogs of checkboxes to select and only then click add, now each channel must be added separately and wait for the interface’s reaction to add the next one.
By the way, someone promised to redo ChartPro so that the added channels appear horizontally at the bottom 🙂December 17, 2021 at 9:14 am #9783Rich Ex
ParticipantHi Many Thanks
On the same subject I then tried to add a link to a CharPro graph but kept getting ‘access denied’ . I used a link from a scheme , the link is http://10.0.0.72/Scada/plugins/ChartPro/ChartPro.aspx?cnlNums=14&viewIDs=2 , as I said this gives access denied .
Maybe I should use a link from a XML file but I don’t know how to write this , help would be appreciated .
Thanks as always
RichDecember 17, 2021 at 1:50 pm #9787
manjey73Participant../ChartPro/ChartPro.aspx?cnlNums=160,161,162&viewIDs=2,2,2&title=Давление Котлов
Perhaps the string should start with ../ following the example above
December 17, 2021 at 1:54 pm #9790
MikhailModerator> This list is to long , can I hide some of the channels from view ?
Thank you for the screenshot. It’s impossible to hide channels in the current version. We will take this into account in the future.> On the same subject I then tried to add a link to a CharPro graph
Where did you insert a link?December 17, 2021 at 1:55 pm #9791
MikhailModeratorYou could create a table view with a limited number of channels to simplify selection. And hide this table view from the explorer tree.
December 17, 2021 at 4:29 pm #9796Rich Ex
Hi yes I did think I could do that , would be nice and easy to just “hide” like in the table view …. maybe in the future .
also <Where did you insert a link?>
I had the link on one of my scheme pages so as the operator could just pull jut a complete graph …. it did not work ‘access denied ‘ error .
Thank you
RichardDecember 20, 2021 at 8:07 am #9806
About the link
1. Open a graph by yourself, setup it as needed, and copy the link
2. Insert the address into the properties of the link component. By cut the beginning of the address, because a relative address is required. Try something like../ChartPro/ChartPro.aspx?cnlNums=14&viewIDs=2
