MikhailModerator> the raspberry pi 3b and the os is raspberry pi os (32-bit)
It is slower than RPi4. You can see in the log that the start of SCADA-Server takes about 1 minute.
Also ScadaWeb.log is needed.-
This reply was modified 2 years, 10 months ago by
MikhailModeratorScadaServer.log and ScadaComm.log are OK.
Also ScadaWeb.log is needed.Which Raspberry version do you use?
MikhailModeratorYou should use a good XML editor that can collapse and expand nodes, so you can check that the XML structure is correct. Otherwise, move to v6. We can update license keys for the new version.
What is written in ScadaServer.log and ScadaWeb.log?
MikhailModeratorFor example
C:\SCADA\Projects\HelloWorld\Instances\Default\ScadaServer\Config\ModAutoControl.xml
Could you provide a screenshot of the error?
MikhailModeratorDoes the PDF of this version still not support Chinese fonts?
Elastic Report 6.0.0.0 cannot load fonts, so it does not support Chinese fonts.
The described method will work with a new Elastic Report version which is expected in August.
MikhailModeratorThe issue will be fixed in the next Elastic Report release. Thank you for reporting.
You will need to:
1. Install a font that supports Chinese, like arialuni.ttf. On Windows, the font must be installed for all users into C:\Windows\Fonts
2. Specify the font name in SCADA\ScadaWeb\wwwroot\plugins\ElasticReport\templates\PdfStyleDefault.xml
For example, ArialUni
Copy and Paste buttons were added in the 6th version of the module.
In the 5th version, you could try editing the ModAutoControl.xml file by an external XML editor like Notepad++.
– Operating system version
– Elastic Report Plugin version
Please provide a link to a screenshot of the device settings in Communicator.
MikhailModeratorThe request is different comparing with the previous version. That means that the device settings were changed. Make sure that you configured the device properly. Use https://rapidscada.net/modbus to check requests.
Please copy the question to the appropriate topic, or create a new topic. This topic is about incorrect data format error.
MikhailModeratorIntegration with Grafana is similar. Grafana dashboards have URL with long GUID. Depending on the settings, they can be open separately by a user who knows that URL.
Rapid SCADA web page can interact with your page by sending HTTP requests. POST requests more hidden from a user comparing with GET requests. For example, your page may require special POST request before providing data.
