Forum Home › Forums › Rapid SCADA on Linux Controllers and Raspberry Pi › Running in Raspberry Pi
- This topic has 12 replies, 3 voices, and was last updated 3 years, 2 months ago by
July 14, 2023 at 6:29 am #12987
ArunRuchir
ParticipantWe followed all the steps explained in earlier threads and now RapdiScada is running in Raspberry Pi. We also copied some of the files from our Laptop to RP as suggested.
However, we are not able to see any Channel or Web page in RP and do not know how to actually run our project in RP.
Can someone help, please?
Version -latest 6.1 in both laptop and RP.July 14, 2023 at 9:30 am #12993
Could you provide a screenshot of the error?July 14, 2023 at 10:13 am #12995ArunRuchir
ParticipantHi Mikhail,
Actually, there are no errors per se.
All services – server, comm, agent, and Web are working fine when we check via
systemctl command on RP. But when we open the web page – nothing is visible.We are not sure how to run a project via RP after creating it in Laptop. Which all files need to be copied, how port numbers need to be changed etc.
Please guide us.
July 14, 2023 at 4:00 pm #12997
What is written in ScadaServer.log and ScadaWeb.log?July 14, 2023 at 4:59 pm #12999ruchir
Participantare you asking what is written in the deployment profile?
July 14, 2023 at 6:05 pm #13000ruchir
Participanthttps://drive.google.com/drive/folders/1l4vLBsxGb0TBFiNsAngrBOMcJuo-Qiuk?usp=sharing
here you find the logs
July 15, 2023 at 6:58 am #13001
MikhailModeratorScadaServer.log and ScadaComm.log are OK.
Also ScadaWeb.log is needed.Which Raspberry version do you use?
July 15, 2023 at 7:57 am #13002ruchir
Participantraspberry pi 4
July 15, 2023 at 8:04 am #13003ruchir
Participantalso the link has been updated with the logs, please check again
July 15, 2023 at 8:23 am #13004ruchir
Participanti apologize , the raspberry pi 3b and the os is raspberry pi os (32-bit)
July 17, 2023 at 9:10 am #13005
MikhailModerator> the raspberry pi 3b and the os is raspberry pi os (32-bit)
It is slower than RPi4. You can see in the log that the start of SCADA-Server takes about 1 minute.
Also ScadaWeb.log is needed.-
This reply was modified 3 years, 2 months ago by
July 17, 2023 at 9:42 am #13007ruchir
scada web log is available
July 18, 2023 at 12:24 pm #13008
MikhailModerator2023-07-14 11:45:28 [RapidScada][root][ACT] The configuration database has been received successfully 2023-07-14 11:45:29 [RapidScada][root][INF] The application is ready for operating
That means that the web app works correctly.
What URL do you use to open it in browser? -
