Viewing 15 posts - 1,456 through 1,470 (of 6,266 total)
  • in reply to: Chart and other Graphics suggestion #13525
    Free charts are available out of the box. No additional configuration needed.
    in reply to: Using Formulas With Scripts #13521
    You should create a more complex function and use it inside EverySec, e.g.,
    EverySec(() => MyFunc)
    in reply to: http command #13520
    Error text was not informational. However, timeout is set for the request when it is created.
    Headers should work. Play with them.
    in reply to: http command #13516
    Check the device timeout. It should be > 0.
    in reply to: http command #13515
    Try simplifying the request and arguments to find the error cause.
    in reply to: http command #13513
    Cannot reproduce: https://ibb.co/S0sW3Tm
    My DrvHttpNotif_XXX.xml is
    <?xml version="1.0" encoding="utf-8"?>
    <NotifDeviceConfig>
      <Uri>http://remote:Hovdetjenn18@10.147.19.135/scada-remote?m=json&amp;r=grp&amp;fn=write&amp;alias={grp}&amp;value={value}</Uri>
      <Method>Get</Method>
      <Headers />
      <Content />
      <ContentType />
      <ContentEscaping>None</ContentEscaping>
      <ParamEnabled>true</ParamEnabled>
      <ParamBegin>{</ParamBegin>
      <ParamEnd>}</ParamEnd>
      <AddrSep>;</AddrSep>
    </NotifDeviceConfig>
    Command string data:
    value=34
    grp=63/7/200
    • This reply was modified 2 years, 7 months ago by Mikhail.
    in reply to: Delay before creating an event #13512
    Automatic Control Module can activate trigger with timeout. But currently the module cannot generate events. If we add to the module a feature to generate events on trigger, does it solve the issue?
    in reply to: Using Formulas With Scripts #13511
    Is there a way to edit the script to make it update every half second instead of every second?
    Open the Scripts table and check the EveryPeriod method. You can use it instead of EverySec.
    in reply to: http command #13510
    I will check.
    in reply to: Using Formulas With Scripts #13501
    If you use this formula inside the channel 101, try
    EverySec(() => { return Val() + 1; }) or
    EverySec(() => Val() + 1)
    The channel should be of the Calculated type.
    in reply to: http command #13500
    Could you also provide a screenshot of the communication line log when you send a command?
    in reply to: Delay before creating an event #13496
    In Rapid SCADA 6 you can set a deadband for a limit. It’s not a time delay but also can be helpful. To make a time delay, you need to develop a formula and change channel status from the formula.
    in reply to: http command #13495
    First of all, try sending command from the device data page (in Communicator settings). Provide screenshots if it doesn’t work.
    in reply to: http command #13494
    With DrvHttpNotif you can send any parameters using GET or POST request.
    You should send a command having the code Request and text like
    grp=value1
    value=value2
    in reply to: Export to database #13483
    Use the SQL examples from this link.
