Viewing 15 posts - 1,216 through 1,230 (of 6,266 total)
  • in reply to: ModDiffCalculator #14139
    Look for useful info in the module log.
    in reply to: ModDiffCalculator #14138
    Tee configuration looks correct. Note that you use Minute archive to read and write data.
    > am I getting data timestamp at every HH:00:00 and HH:30:00 exactly?
    Yes, if Offset is 00:00:00.
    in reply to: How to use PlgSchExtraComp plugin #14136
    Use this temporary link to download the videos. Please publish them to Chinese video websites and provide a link here on the forum for other users from China.
    in reply to: Add calculated channels to OPC UA Server #14135
    OPC UA server works on the Communicator level, so it has no access to values of calculated channels. Do solve the task as you described, there should be an OPC UA module working on the Server level.
    Consider alternative solutions:
    1. MQTT Publisher driver (DrvMqttPublisher.dll) can publish channel values.
    2. Send Telegram/email/SMS notifications using Rapid SCADA.
    in reply to: Internal Server Error with Map Plugin #14129
    You downloaded the latest version, and helped to find a bug. Thank you.
    The bug is related to our recent upgrade from .NET 6 to .NET 8.
    in reply to: Internal Server Error with Map Plugin #14127
    To fix the issue, upgrade PlgMap to the latest version 6.1.0.0.
    in reply to: Internal Server Error with Map Plugin #14126
    Thank you for the report.
    We will check and let you know.
    in reply to: Formula lowestValue #14125
    When Server starts, it loads channel values that saved before it Server stop. Value is reset because of your function. Using DayStarted() may help not to reset lowest value on start.
    in reply to: How to use EveryPeriod Function? #14124
    Add a function like that:
    public CnlData Every5Sec(Func getDataFunc)
        return EveryPeriod(getDataFunc, TimeSpan.TicksPerSecond * 5, TimeSpan.TicksPerMillisecond * 500 * 5);
    > I’m still confusing why we still need execSpan argument?
    It is needed to avoid unnecessary calls of getDataFunc.
    in reply to: Mail settings #14123
    Check the videos: link 1, link 2
    Note that currently Gmail does not support sending emails from 3rd party apps. You need another mail server to do that.
    in reply to: Where is the Computer Code? #14122
    OK
    in reply to: How to config “Event”? #14121
    Specify the channel limits, and configure event mask of the channel.
    in reply to: How to use PlgSchExtraComp plugin #14118
    This video can help.
    in reply to: Scheme Editor cannot load from Administrator app V6.0.2 #14117
    Open Administrator – Options – File Associations and make sure that ScadaSchemeEditor.exe exists there. It should be by default.
    in reply to: Formula lowestValue #14107
    There is a ready to use DayStarted() function. It equals to true in the beginning of the day. Probably, using this function inside your formulas can fix the issue.
    If you provide screenshots of your channels, I can check them.
