ModDiffCalculator
Forum Home › Forums › Understanding the Software › ModDiffCalculator
Viewing 13 posts - 1 through 13 (of 13 total)
  • #14137
    kcks66
    Hi Mikhail,
    Thanks for the ModDiffCalculator module to try. I wish to get energy usage for every 30 minutes. My source channel 101 is cumulative kWh from energy meter, destination channel 102 is energy consumption every 30 minutes calculated channel type.
    Kindly advice whether my configuration is correct?
    https://ibb.co/x6b1F1x
    One more thing is I set 30 minutes different; am I getting data timestamp at every HH:00:00 and HH:30:00 exactly?
    #14138
    Tee configuration looks correct. Note that you use Minute archive to read and write data.
    Yes, if Offset is 00:00:00.
    #14139
    Look for useful info in the module log.
    #14140
    kcks66
    Hi Mikhail,
    I have one question; example if there is no data/data lost (channel 101) before 9:00:00 PM but resume back before 9:30:00 PM, what happen to the ModDiffCalculator module to calculate (channel 102) at 9:30:00 PM?
    Channel 102 (9:30:00 PM, data?) = Channel 101 (9:30:00 PM, got data) – Channel 101 (9:00:00 PM, no data)
    Pls advice and thank you.
    #14141
    To calculate the difference, the both data points must be defined. Otherwise, the difference is not calculated. In that case, you can set data manually, and then send a command to recalculate diffs for the period of time.
    #14146
    kcks66
    Hi Mikhail,
    Noted. Going to give it a try. Thanks.
    #14147
    kcks66
    Hi Mikhail,
    I configured custom period to 00:30:00. Somehow after I saved and upload to server the custom period became 00:00:00. I tried many times the custom period looks like always reset to 00:00:00.
    <ModDiffCalculator>
    <GeneralOptions>
    <CmdCode />
    </GeneralOptions>
    <Groups>
    <Group active=”true” name=”30 Minutes” periodType=”Minute” offset=”00:00:00″ delay=”10″ archiveBit=”1″>
    <Item srcCnlNum=”101″ destCnlNum=”102″ />
    </Group>
    </Groups>
    </ModDiffCalculator>
    The module log:
    https://ibb.co/BnVg8wD
    I checked result from excel is the different calculation is based on 1 minute.
    https://ibb.co/NFGbz1t
    #14148
    kcks66
    I should select custom period then is ok.
    <ModDiffCalculator>
    <GeneralOptions>
    <CmdCode />
    </GeneralOptions>
    <Groups>
    <Group active=”true” name=”30 Minutes” periodType=”Custom” customPeriod=”00:30:00″ offset=”00:00:00″ delay=”10″ archiveBit=”1″>
    </Group>
    </Groups>
    #14157
    Right, you need to set Period type = Custom before saving the configuration.
    #14161
    kcks66
    Hi Mikhail,
    I got the result in Minute archive as shown below:
    https://ibb.co/jfwNKx8
    I see every 30 minutes got data as expected. Somehow there is always 0 if out of HH:00:00 and HH:30:00. Is ModDiffCalculator working like this?
    The other part is data channel 102 always 0 in the Table, as below:
    https://ibb.co/hCxX9Gj
    Since the Channel 102 always show 0 I couldn’t use to attach to a Dynamic Text in Scheme as well as use as source channel for another calculated channel to further formula function.
    Pls advice for my ModDiffCalculator configuration:
    #14165
    I suggest to use the hourly archive instead of the minute archive. This helps to avoid 0 between data points. You can set 30 mins period for the hourly archive.
    Schemes display the current data, while ModDiffCalculator works with historical data. To display historical data, use table views and reports.
    Because a table view displays data from the hourly archive by default.
    #17611
    grhsc
    Sorry to reopen this topic, but power outages and network errors are frequent problems encountered during data collection from electricity and water meters.
    this is your reply
    I’d like to know the operational details of this step; could you please help me? – you can set data manually, and then send a command to recalculate diffs for the period of time
    #17613
    1. To set data points manually, use the utilities.
    2. To recalculate differences, send a command to the module. Command example:
    cmd=Calculate
    startDT=2024-02-26 10:00:00
    endDT=2024-02-26 11:00:00
    Time in UTC.
