Where is the Computer Code?
Forum Home Forums Understanding the Software Where is the Computer Code?
  • #14113
    ChZeman
    I’m trying to evaluate Rapid SCADA and I’m not off to a good start. I want to obtain a Trial Key for the dashboard plugin and referred to Step 10 as indicated in another post.
    If the module requires registration:
    When started, the module writes the computer code to a file. In the Administrator application, select the module and click the Register button.
    So where is the file and what is it called? Why isn’t such an item available from the administration interface so it’s readily accessible if it’s needed to register plugins?
    #14114
    ChZeman
    I didn’t do anything, but it suddenly showed up the 10th time I went into module Registration.
    #14122
    OK
