Viewing 15 posts - 6,106 through 6,120 (of 6,265 total)
  • in reply to: dynamicaly change the cmdnum or adress #483
    The module version 4.5 is ready, but not published yet. I can send it by e-mail.
    This module is not free that is why there is no its sources on GitHub.
    The specified cost of licence applied to a one computer. If you are going to purchase a large number of licenses, discount is possible.
    At this time I’m not ready to share the source even for a money. If you need some improvements, we can discuss it.
    In most cases update is free. It could be payable if the module functionality significantly increases. DLL update is necessary, if SCADA-Server API changes.
    in reply to: dynamicaly change the cmdnum or adress #481
    The general sequence:
    1. Create one output channel with Command number = 1 and Command values = Off-On
    It allows to send 0 – off, 1 – on
    2. Using the module add 2 Command Triggers.
    The 1st fires on 0 value of command 1. The 2nd fires on 1 value of command 1.
    3. Create a one new command under the each trigger with the required command numbers.
    If you have already updated Rapid SCADA to version 4.5, please, let me know for sending you the module update.
    in reply to: dynamicaly change the cmdnum or adress #476
    Each output channel is bound to the only one command number. In your case you are going to send different commands using the single output channel. It is possible with help of Automatic Control Module
    Download the trial and try to realize how it works. If help is needed, write here.
    in reply to: Any questions about Rapid SCADA and Raspberry Pi #475
    Hi Dejan,
    I’m sure, it is possible, but hasn’t be done before. If you’d like to do it, I’ll try to help you.
    in reply to: Any questions about Rapid SCADA and Raspberry Pi #468
    It seems like problems in the equipment.
    in reply to: RapidScada 4.5 Install #467
    Probably, something wrong in WCF. If you have an opportunity to chack on another computer, please do it.
    in reply to: RapidScada 4.5 Install #463
    Fress F12, then go to Console and try to find the errors )
    in reply to: RapidScada 4.5 Install #461
    “Specified cast is not valid” is fixed.
    I need more info about auto update issues. Could you provide the info?
    in reply to: Any questions about Rapid SCADA and Raspberry Pi #458
    Seems that problems are in the USB adapter or the wires. If you connect this adapter to Windows computer, does it work correctly?
    in reply to: RapidScada 4.5 Install #454
    1. ScadaSetup.exe is fixed. It does not affect work of the applications.
    2. There is a bug, but I can’t reproduce it. If you know how to do it, please write. Send me C:\SCADA\ScadaWeb\log\ScadaWeb.log please
    in reply to: Any questions about Rapid SCADA and Raspberry Pi #451
    Please look the file /etc/scada/ScadaComm/Log/lineXXX.log
    (where XXX – your communication line number)
    for the addition information
    in reply to: RapidScada 4.5 Install #450
    Hi Romiros,
    1. Setup should install MS SQL Compact on your machine. Could you remember whether it was done?
    2. Refresh the page using Ctrl+F5. The subfolder of Diag.aspx is changed.
    Thanks for the information!
    in reply to: Any questions about Rapid SCADA and Raspberry Pi #447
    Please send a larger piece of the communication log.
    in reply to: Is it possible to connect SCADA with PostgreSQL #445
    It is a special format.
    This article helps you.
    in reply to: Any questions about Rapid SCADA and Raspberry Pi #444
    It is here
