RapidScada 4.5 Install
Forum Home › Forums › Installation Issues › RapidScada 4.5 Install
Viewing 12 posts - 1 through 12 (of 12 total)
  • #449
    Romiros
    Hi, Mikhail.
    I installed RapidScada 4.5 on Windows 7. The installation went without error.
    But there are some problems:
    1. Scada-Administrator is crushed when connecting to database (version 4.4 worked good)
    2. In ScadaWeb dont work chart (Error: The file ‘/Scada/Diag.aspx’ does not exist. )
    #450
    Hi Romiros,
    1. Setup should install MS SQL Compact on your machine. Could you remember whether it was done?
    2. Refresh the page using Ctrl+F5. The subfolder of Diag.aspx is changed.
    Thanks for the information!
    #452
    Romiros
    Thank you Mikhail
    1. MS SQL Compact has not been install. I installed manually (Now Scada-Administrator works well).
    2. New error: Specified cast is not valid.
    #453
    Romiros
    2. a new day – all works 🙂
    #454
    1. ScadaSetup.exe is fixed. It does not affect work of the applications.
    2. There is a bug, but I can’t reproduce it. If you know how to do it, please write. Send me C:\SCADA\ScadaWeb\log\ScadaWeb.log please
    #457
    Romiros
    I send you ScadaWeb.log. The error disappeared when the new minute archive started.
    But new error – Failed to auto-update chart.
    #461
    “Specified cast is not valid” is fixed.
    I need more info about auto update issues. Could you provide the info?
    #462
    Romiros
    What information do you need?
    #463
    Fress F12, then go to Console and try to find the errors )
    #464
    Romiros
    I do not know will help or not
    IExplorer:
    14‎:‎24‎:‎50 Request diagram data. TimeOffset = 0.59930556712963
    error: 404 Not Found
    Chrome:
    POST http://localhost/Scada/diag/DiagSvc.svc/GetDiagData 404 (Not Found)
    #467
    Probably, something wrong in WCF. If you have an opportunity to chack on another computer, please do it.
    #469
    Romiros
    Yes you are right. Phe problem was wcf. Now all works. Thank you!
