Viewing 15 posts - 5,866 through 5,880 (of 6,265 total)
  • in reply to: Firefox left w/ graphs open overtakes RAM #1056
    Of course. I do the best to make this moment closer.
    in reply to: Communicator using 100% CPU #1055
    I need somehow to reproduce the problem on my PC. Do you have any idea how to do it?
    in reply to: I cant see Scada Comunicator window #1052
    SCADA-Web is installed incorrectly. Try reinstall SCADA-Web. If the installer shows error, post it here.
    in reply to: Firefox left w/ graphs open overtakes RAM #1051
    My results for the current version of SCADA-Web after 1 or 2 hours of work:
    FF – changed: 1.2GB => 400 MB => 600MB => 20MB – freeze
    IE – increased to 600MB – freeze
    Edge – changed: 15MB => 3MB, but background Edge process 2GB
    Chrome – changed: 25MB => 15MB, but background Chrome process eats RAM, sometimes page can’t be displayed and memory is cleared – not fair
    I will try with old jQuery. The jQuery ticket that you found is very interesting.
    New scheme engine after the night:
    FF – 130MB
    Chrome – 17MB + 21MB background Chrome process
    in reply to: Communicator using 100% CPU #1050
    It’s already done, that’s what is weird!
    Did you mean that Delay after request cycle parameter solves the problem?
    in reply to: Failure in connect with OPC server #1049
    Is it a screenshot of your OPC server?
    in reply to: Firefox left w/ graphs open overtakes RAM #1042
    Periodically I do similar tests. I should repeat them.
    That’s funny, but a few years ago SCADA-Web run stable on IE for days. And Chrome supported Silverlight 🙂
    I think that the cause of memory leak is reloading frames within web page. This approach is outdated and will be changed to REST API.
    in reply to: Communicator using 100% CPU #1041
    Shouldn’t apply delay in case of any error too?
    I think that you did is enough.
    Where can I get it?
    It will be included in the next version. In case we found the workaround I think you shouldn’t update Communicator. But if you wish, I can send it by email.
    in reply to: Communicator using 100% CPU #1039
    As I realized the most fast communication if UDP is used directly for a serial converter without virtual port and C:\SCADA is ignored by anti-virus system.
    in reply to: Communicator using 100% CPU #1038
    Without a delay Communicator tries to write in the loop. So CPU become loaded.
    I will add the fix in the core of Communicator.
    Does the connection repair automatically or you need to restart Communicator?
    in reply to: Communicator using 100% CPU #1035
    I have an idea:
    set Delay after request cycle parameter of the communication line to 100
    Please write about the result
    in reply to: Communicator using 100% CPU #1033
    Unfortunately, write method is very simple:
            public override void Write(byte[] buffer, int offset, int count,
                CommUtils.ProtocolLogFormats logFormat, out string logText)
                try
                    SerialPort.DiscardInBuffer();
                    SerialPort.DiscardOutBuffer();
                    try
                        SerialPort.Write(buffer, offset, count);
                        logText = BuildWriteLogText(buffer, offset, count, logFormat);
                    catch (TimeoutException ex)
                        logText = CommPhrases.WriteDataError + ": " + ex.Message;
                catch (Exception ex)
                    throw new InvalidOperationException(CommPhrases.WriteDataError + ": " + ex.Message, ex);
    It drops on SerialPort.Write, where SerialPort is standard .NET class.
    Probably serial port driver causes CPU load.
    Does your converter support direct connection as TCP client or TCP server without virtual port?
    For instance, Moxa NPort converter works correctly if connection is lost.
    in reply to: Firefox left w/ graphs open overtakes RAM #1031
    Is there any known memory leakage that could make this?
    Chart component uses JavaScript and web service. JavaScript has auto memory management and should work correctly. Let’s compare with other browsers. Close all other pages except chart.
    in reply to: Firefox left w/ graphs open overtakes RAM #1030
    Is the only chart web page is open? I mean do you close the main web form with scheme or table view?
    When you test the same with IE and Chrome please write about the result.
    in reply to: Communicator using 100% CPU #1029
    Please, post a part of the communication line log when this situation occurs.
    If you stop communication line (from context menu), CPU load become low?
