The manual is inside the installation package. The file name is Doc\dbexport_en.pdf
Try using database model and scripts from the manual.
MikhailModeratorI think it will be good idea to implement connection timeout. It will be done in a one of the future version of Rapid SCADA. Also this work can be accelerated on commercial basis.
MikhailModeratorAs an option you can split polling into several communication lines to communicate in parallel.
How long does it wait if connection can’t be established?
MikhailModeratorLook for the cause in C:\SCADA\ScadaServer\Log\ScadaServerSvc.log
MikhailModeratorThe cause that Mono can’t compile the line 79
initialCmdVal = 0.0;
that is shown in ScadaServer/Log/CalcEngine.cs
MikhailModeratorDo you use comma as decimal separator?
I think the most simple way to switch location and language back to English and check whether error disappear or not.
MikhailModeratorSuch error appears on Germany localization because of Mono bug. What OS culture do you use?
Look at C:\SCADA\ScadaServer\Log
What are in log files?I strongly recommend to use RAM drives for log folders in case of using SD card.
MikhailModerator🙂
MikhailModeratorThanks for the info.
MikhailModeratorI did not know how to install only ScadaWeb
You can choose checkboxes in the installer.
Anyway you have installed it 🙂
MikhailModeratorDear Tarak,
If you mean showing sliders, you should create a set of images using your favourite image editor in PNG or JPG format. Each image will contain their own level. Then open SCADA-Scheme Editor and use Dynamic picture component. Configure Conditions property of the component to show an image according to input channel value. Don’t forget to specify Input channel property.
MikhailModerator
MikhailModeratorThanks!
I will try to “Install lantronix virtual serial COM port software on your computer and connect to my device over the Internet”.If I can’t connect then try to “direct access to the computer running communicator (i.e.: teamviewer) to do ANY tests”
Let’s continue on the next week, OK?
MikhailModeratorHm, scrollbar used to be, but disappeared )
