MikhailModeratorThis features will be added in the plan as soon as we can. This is a major task.
MikhailModeratorYes, you can add svg to a scheme. You should create a set of images with different level of liquid and change a picture according to a value. We are going to create ready to use controls for this purpose.
You should create commands in Template Editor and create output channels by Administrator.Also, how do I create a control where I can enter the value of the new SetPoint for the output channel?
You should define output channel number for dynamic text or picture of a scheme and choose action – Send command. If you use table views, define output channel for a row.
This reply was modified 8 years, 7 months ago by
Currently, you should use formulas of output channels to swap bytes.
But the new version of the driver, which supports swapping bytes for commands, is under construction now.
If you can wait for a week, we can send you a new version. In this case, please write an email to our info@…org
Otherwise, please translate this answer by Google Translate.
Could you make screenshots of the settings of the module?
If you stop the Communicator service and manually send data from Generator of the Server shell, will you get the same errors right after restart?
MikhailModerator
What kind of tasks do you need to schedule?
For example, there is a time trigger in Automatic Control Module.
MikhailModeratorYes, it’s OK. I haven’t worked with Google Cloud, I used Microsoft Azure. I think they are similar.
Please paste communication line log here.
You should check firewall. Probably, outgoing connection to TCP port 502 is prohibited. Web interface uses port 80 which is usually permitted.
MikhailModeratorSetCulture.exe is a console application. Run it from the command line.
Download the Linux distributive. Then run SetCulture.exe on your Windows computer. It allows to easy switch culture. Set en-GB culture.
Could you provide screenshot of the “SCADA-Administrator has stopped working” error?
MikhailModeratormanjey73, you can switch to English in Administrator settings and then reopen applications.
MikhailModeratorI agree, in the future it’s better to switch language before taking screenshots. But for now, you could open the same forms in English and you will understand what controls and columns are meant.
MikhailModeratorThis is context adv different based on interests of a watcher 🙂
Do you have any questions that we have not clarified yet? Be free to ask
MikhailModeratorAre there any girls in the examples?
