Viewing 15 posts - 5,041 through 5,055 (of 6,266 total)
  • in reply to: Email sender bug #3109
    You can generate events manually using Server. Can you reproduce the error by creating an event such way?
    in reply to: Averaging values #3108
    Good 🙂
    in reply to: SCADA Comunicattor – Events not received #3107
    Do events shown in Webstation?
    Make a screenshot of the Device Data page of Communicator where tags and events are visible.
    in reply to: SCADA Comunicattor – Events not received #3102
    When you get “Unknown event source” error, the event is not received, so you can’t send it by email.
    in reply to: SCADA Comunicattor – Events not received #3101
    When an event is received from an OPC server, it contains tag name, called Event Source. You should add the tag “localhost.Sample Structured Text Program” to a DA subscription.
    You wrote in another topic that you use Automatic Control Module to send events by email. Does it work for now?
    in reply to: Averaging values #3098
    It is possible to solve the task by creating formulas in the configuration database. Formulas are based on C#. Do you know C#?
    in reply to: too many "normal" event #3097
    If it occurs again, let’s continue this topic.
    in reply to: Email sender bug #3096
    What text contains the events that cause the error? How to reproduce the error?
    in reply to: too many "normal" event #3087
    Yes, “normal” event should be created after low or high statuses. What version of SCADA-Server do you use?
    Tick “On undefined” checkbox, may be it helps to realize the cause.
    in reply to: Averaging values #3085
    What period of time and how many points should be included in average value?
    in reply to: too many "normal" event #3080
    Please make a screenshot of the input channel for the sensor. If you double right click a row of a channel, a properties dialog can be shown.
    • This reply was modified 8 years, 3 months ago by Mikhail.
    in reply to: Averaging values #3079
    If you tick the Averaging checkbox, it affects on minute and hourly data stored in the archive. But not affects current values. You need custom formulas or develop module that perform averaging.
    What averaging algorithm do you need?
    in reply to: Automatic Control Module – Send eMail #3078
    Use address book in Communicator to manage subscribers.
    in reply to: Automatic Control Module – Send eMail #3077
    have the fixed email content associated with each separate trigger?
    You should create commands for each trigger. May be I don’t understand the question.
    in reply to: Automatic Control Module – Send eMail #3076
    Yes, port 587 is entered by default in the configuration, and it works.
    Answer:
    Definitely. See available variables at http://doc.rapidscada.net/content/en/modules/mod-auto-control.html
    Example: your_email@gmail.com;subject;{Now} Name: {CnlName}, value: {CnlVal}
