too many "normal" event
Forum Home › Forums › Understanding the Software › too many "normal" event
  • #3074
    tripode
    Hi, I have set up an analog sensor with some oscillations, but the event log is flooded with many “normal” indications. I think the “Normal” event should come only when the value goes back to a normal status after a ‘low’ or ‘high’ event/alarm.
    How could I stop this flood of events?
    Thanks in advance.
    #3080
    Please make a screenshot of the input channel for the sensor. If you double right click a row of a channel, a properties dialog can be shown.
    • This reply was modified 8 years, 8 months ago by Mikhail.
    #3083
    tripode
    https://imgur.com/a/AHOXK
    • This reply was modified 8 years, 8 months ago by tripode.
    #3087
    Yes, “normal” event should be created after low or high statuses. What version of SCADA-Server do you use?
    Tick “On undefined” checkbox, may be it helps to realize the cause.
    #3089
    tripode
    SCADA-Server version 5.1.0.2
    I have reset all and now it seems to work again. What I had before was many “normal” events on the same channel, but one after another (not just once recovered the ‘normal’ status).
    #3097
    If it occurs again, let’s continue this topic.
    #4092
    leon
    Solved
    • This reply was modified 8 years, 2 months ago by leon.
