Viewing 15 posts - 4,936 through 4,950 (of 6,266 total)
  • in reply to: localhost/scada/ #3366
    Thank you for the info.
    in reply to: Mail SMTP Set #3362
    I wrote:
    After you send emails from Communicator, you will setup Administrator and Automatic Control module.
    So at the first, you should fix sending using Communicator only.
    in reply to: Source Code KpOpc.dll #3361
    OPC DA doesn’t work on Linux because it uses Windows DCOM, while OPC UA should work.
    Other Rapid SCADA drivers work on Linux and the web app also works well.
    in reply to: localhost/scada/ #3360
    Open IIS management console and check if ScadaWeb application exists. It should be displayed as a subnode of Default Website.
    Does C:\SCADA\ScadaWeb directory exist?
    Those who are faced with this problem, write your comments in this topic, please.
    in reply to: Mail SMTP Set #3350
    leon, first of all, make sure that you can successfully send emails from Communicator. You don’t need other apps for testing, just Communicator. Send commands from the Command tab.
    in reply to: Source Code KpOpc.dll #3349
    I’m looking for updated KpOpc.dll sources if possible.
    Why don’t you put them on Github ?
    Take them here. I’m not sure about license of classic OPC, while OPC UA .NET API is definitely open sourced by the manufacturer.
    My goal is to implement OPC UA in RapidScada.
    It would be great!
    in reply to: Channel Status #3348
    Please provide screenshots of Communicator where we can see how data are polled.
    in reply to: Application require system Admin rights to start #3347
    Yes, the apps require administrator access. The cause is that SCADA-Server and Communicator are Windows services. So to make possible to control them, you need administrator privileges.
    in reply to: localhost/scada/ #3346
    Try http://localhost/ If you don’t see IIS welcome page, you should install IIS as written here http://doc.rapidscada.net/content/en/installation-and-run/software-installation.html
    If IIS is already installed, may be you should fix it.
    in reply to: Mail SMTP Set #3335
    See the description at Device Libraries – KpEmail.dll
    You need a Binary command number 1 with a text that Joao noticed above.
    • This reply was modified 8 years, 2 months ago by Mikhail.
    in reply to: Connecting to cloud #3334
    API is not a file system. You should check documentation of that software what API it supports.
    in reply to: Channel Status #3333
    You can see the statuses in the Event types table.
    5 is Unreliable
    It means that there are no data for a period (by default 5 mins). You should check if Communicator works or not.
    in reply to: Understanding Inputs Outputs and formulas #3326
    Now ushort is selected that is always >= 0. To make possible negative values, switch to short. Then save the template and restart Communicator.
    in reply to: Connecting to cloud #3325
    What API of that system do you plan to use?
