If you have a formula for an input channel, it affects. You didn’t provide a screenshot of the input channel, so I’m not sure.
How to reproduce the issue on my side?
MikhailModeratorThe single digit display cannot be 0.2.4.6~…..
Ten digits display normalHi,
I don’t understand the question. Could you explain?
In the Current Data tab you need to enter INSERT request only. Other SQL scripts are needed for creating the database.
MikhailModeratorrsepulve,
it would be clear if you provide screenshots of your settings.
IP address of a GSM device is specific to a telecommunication company. Sometimes they provide real IP for extra fee. This approach is not flexible. That’s better when a modem connects to a server.
IP addres I have to put in coomunication settings dor slave devie?
IP not needed if a modem initiates a connection.
MikhailModeratorYou should provide screenshots of the module settings and log of the export module.
MikhailModeratorThank you!
MikhailModeratorWow!
Could you show the screenshots before and after?
The above screenshot is too small. I can’t recognize anything.
MikhailModerator1. Go to the Modules page
2. Click the Add (+) button
3. Add ModDBExport.dll and apply the settings.
4. Select the module and click the Properties button.
You should create a new database connection in the module properties form and paste SQL requests for this connection.
What is the particular question?
This is a bit strange. On the other hand, I’m sure that the cause exists. Could you provide screenshots of the related input channels?
Configuration of Rapid SCADA is prepared on Windows, then applied on Linux. I recommend watching the videos to learn how to configure Modbus.
MikhailModeratorI’ve opened an issue on Mono https://github.com/mono/mono/issues/9458
Hope the Mono team will work on it.
MikhailModeratorHi Rodrigo,
Usually a modem is TCP client while Communicator is TCP server. You should set the TCP server type of communication channel in Communicator and allow the incoming connection on Firewall. Setup a modem to connect to the IP or DNS name and TCP port of your server. You will see that a connection is established in a communication line log. If connection is OK, Communicator polls the devices.
If something goes wrong, provide logs of the communication line.
