MikhailModerator
Could you illustrate the issue #1 by a screenshot?
MikhailModeratorI agree that this is an important issue. Thanks for paying attention to this.
MikhailModeratorI asked for a screenshot but I see *.json file.
I sent you an email.
MikhailModeratorIs there a method like Connect to connect to the OPC server?
MikhailModeratorThere is no screenshot by this link. At least on my PC.
It affects hourly table views.
When you see “rockets” at http://demo.rapidscada.net/View.aspx?viewID=22 near Light and Aeration, this is because of this column.
MikhailModeratorI suppose the URL here is the ID of the OPC server, e.g. Matrikon.OPC.Simulation/{f8582cf2-88fb-11d0-b850-00c0f0104305}
MikhailModeratorPlease make a screenshot of the browser console (Press F12 in browser).
MikhailModeratorTechnically, report generation should be moved from the web app to a service. It requires redesign of the part of the internal structure of the source core.
This function would be useful. We are ready to implement it as a part of commercial contract.
MikhailModeratorWhy you don’t pass valid URL to new OpcCom.Da20.Server(url, server)?
This URL is needed to specify the server you connect.Why does not call a implementation of IServer instead?
Interface is just a declaration. The runtime executes the method of an object that was actually created.
MikhailModeratorI think the only way at this time is written here. I mean using reverse proxy.
1. This may be a heavy solution: create channels that indicate out of bounds and tick the checkbox to write events on change of these channels.
2. Add generating events function to Automatic Control Module.
3. Update Rapid SCADA mechanism of generating events. This is the best option.
The 2nd and the 3rd items could be done on commercial basis faster. Or wait when we implement them for free.
and assign thresholds to formulas that will change the status of your new notifications
Yes, but changing status doesn’t generate events.
