I am running version 5.5.3
I am using the Matrikon OPC Sawtooth Real8 as input, and use it in another Calculated Real channel, with the Average box checked.
Two issues:
1.) checking the Average box, it appear checked in the input channel list view, but not checked in the channel property view. I tried this both with and without using a formula. I also tried this on both a REAL channel from OPC source, and a Calculated Real channel.
2.) checking the Average box, viewing the ChartPro will display values ranging from 6 to 191 for the minutes. This cannot be correct as the values input range from 0 to 198 within 70 seconds should result in a more steady curve when averaged over the 60 seconds period.
Thanks.
