MikhailModeratorHi Hugo,
We can do the required feature for a free. If you interested, write an email that contains detailed requirements. And we would estimate the cost of development.
why “%256”, “/256”,what it is doing, I really do not understand.
Gets lo and hi bytes of the integer.
Or I need make function which handle such future?
Yes, you should use extra input channels.
In VS goto Debug -> Attach To Process and find ScadaServerSvc.exe
You did everything right.
MikhailModeratorYou should test schemes in Firefox and Edge. Do they work?
Dynamic text shows value of an input channel, that is in turn can be calculated by a formula.
MikhailModeratorshould we compile ScadaAdmin5 or ScadaAdmin?
It is not ready, but you can run it just for watching.
MikhailModeratorDo table views work correctly?
If you update the existing web app, press Ctrl+F5 to fully refresh scripts.
You should also refresh dll repository. WinControl.dll changed.
1. Create your own database that contains user credentials.
The database model is up to you.2. Create a module for SCADA-Server that checks user login and password.
Use ModActiveDirectory as a template.
Override ValidateUser method.3. Create a plugin to manage users.
This is a plugin for Webstation that implements editing your database.
Plugin examples are here.
You should remove Rapid SCADA using the ScadaSetup.exe
Make sure that C:\SCADA doesn’t extist after uninstall.
Install Rapid SCADA again.
MikhailModeratorI’m not an I.T wizzard, so can you explain how to get it working with my remote client being connected on a different network, far away?
Is manjey73 said, VPN is the most preferable and safe way.
Also you can use dynamic DNS service, such as https://www.noip.com/ In this case, you need to register the service, enter the credentials into your router, setup NAT on the router, and then connect like youraddress.ddns.net/scadaJanuary 9, 2019 at 1:16 pm in reply to: SCADAComm stop attempt to reconnect when communication failed #4834
MikhailModeratorOK, I added the author to email thread. Hope he will answer.
