Dynamic text capability
Forum Home › Forums › Uncategorized Issues › Dynamic text capability
  • #4851
    Horacio
    Hello
    Can dynamic text (Scheme Editor) show the result of a formula that uses values coming from different devices?
    If not, is it a way to do it?
    Thank you
    Best regards
    Horacio
    #4855
    Dynamic text shows value of an input channel, that is in turn can be calculated by a formula.
    #4857
    Horacio
    Thank you Mikhail.
    How can I do to show in a Scheme the result of a calculation (formula) that uses values coming to Scada from different devices.
    Perhaps doing the calculation in an output channel of a certain device and show the output channel as dynamic text?
    #4858
    Horacio
    Hello
    I accomplished it by adding an Input Channel to one of the devices with “Calculated real” type. In my case is channel 41.
    I entered there a formula, for example: Val(615) * Val(32),
    being 615 and 32 the numbers of the channels coming from different devices.
    Afterwards, in Scheme Editor I put a Dynamic text indicating to show the value of input channel 41.
    This worked out for input channels from different or from the same device.
    Thank you for support.
    #4860
    You did everything right.
