August 12, 2020 at 1:37 pm in reply to: push data to third-party station or another rapid scada station #7145
1. From the archive that is maintained by SCADA-Server.
2. Yes. use Rapid Gate for this purpose.
Agree. In the version 6 we will implement something like that.
MikhailModeratorIf something goes wrong in the above sequence, please provide screenshots.
You should install Communicator and Agent applications on the remote PC. Then add an additional instance in the Rapid SCADA project. Communicator on the remote PC should refer to the IP address of the main Rapid SCADA server.
MikhailModeratorTry uninstalling the item “WCF Services” and then installing again.
MikhailModeratorIs there a file C:\SCADA\ScadaWeb\ClientApiSvc.svc ?
MikhailModeratorThe features seems correct. They are identical to my Windows 10 workstation.
If you open http://localhost/Scada/ClientApiSvc.svc , what do you get?
MikhailModeratorChanges have been included in the language pack.
I received the files. Thanks a lot! I will check them and write to this topic.
MikhailModerator
Very interesting!
What kind of tasks are solved by the module?
Does it send the predefined commands in the specified day and time?
Can it send a command once on a particular date?
MikhailModeratorThank you for the solution.
Yes, you can. You should select a camera that provides it’s own web page containing video stream. Also it’s important to disable camera login. Then specify the camera’s web page address into a frame component.
MikhailModeratorYou should check this thread.
May be this cause:
I had exactly the same problem. I found that I had a windows printer setup to use the same port. As soon as I changed the port in the printers settings, the SerialPort.Open() worked.
MikhailModeratorOh, I’ve just realized that not all files were translated.
