Viewing 15 posts - 3,571 through 3,585 (of 6,284 total)
  • in reply to: Multilanguage on Schemes #7369
    Sure. Everything can be translated. If you’re asking for advice how to do it, I can help.
    in reply to: Access Rapid SCADA data from Node-RED #7368
    @kumajaya thank you for your help. It is very useful. We will check this.
    in reply to: Server problem #7367
    What is the SCADA-Server version?
    in reply to: Server problem #7366
    Application shutdown means that the web server stops the web application. It is not related to SCADA-Server.
    When the server is in error state, what is written in server and communicator logs?
    in reply to: Displaying units in a table view #7365
    There is no such option. Units are displayed inside a popup when you move a mouse pointer to an item icon.
    in reply to: send command #7364
    1. Add a button on a scheme.
    2. Set the Action property to Send command.
    3. Specify an output channel that needed to send command to a device.
    in reply to: ModAutoControl executing a binary file on event ? #7354
    Starting scripts feature requires development of a module for SCADA-Server.
    in reply to: How to use Notification plugin? #7353
    Adding custom text to events requires additional development. It’s better to implement this feature in Rapid SCADA 6 in the next year. However, we can do it earlier in the version 5 according to a contract.
    in reply to: Scheme Editor Error opening browser in Ubuntu 20 #7352
    Check the editor settings that a default browser is selected.
    I recommend editing Rapid SCADA projects on Windows then upload them to Linux.
    In the future, Microsoft doesn’t plan provide .NET Forms on Linux Desktop, so the full editors will be on Windows, and may be we will provide a simple web editor.
    This means that likely it’s possible to make the driver work with different security levels. Because the driver uses the same OPC UA libraries. Debug needed.
    I can connect to Node OPCUA server now without modified source code.
    Good.
    I can connect with every 7 combination supported by Node OPCUA from UaExpert dan Prosys including “None and None” but only “Sign & encrypt and Basic256Sha256” with KpOpcUa.
    Interesting. Could you also try this official utility made by OPC Foundation? The source code of the utility is available on OPC Foundation’s GitHub if needed.
    in reply to: How to use Notification plugin? #7343
    The notifications are based on the events in the archive.
    Probably, you should untick the “Event on Change” property of the input channel.
    in reply to: How to set up Telegram #7337
    Write to the bot:
    /info
    If it doesn’t answer, check the communication line log in Communicator.
    in reply to: How to use Notification plugin? #7336
    The manual.
    <Statuses>612</Statuses> – you should put statuses there, not channel numbers. Look for the existing statuses in the Event types table.
    <ParamIDs>11</ParamIDs> – may be it’s better to set empty string inside.
    I’ve copied my answer from GitHub:
    Thank you for the pull request, but I can’t merge it because of the following:
    1. Pull requests in this repository should be targeted to the develop branch.
    2. Removing the lines makes impossible to apply the corresponding configuration options.
    3. You should try changing the device configuration in KpOpcUa_XXX.xml to use the correct SecurityMode and SecurityPolicy.
    Please try the 3rd item and let me know about the result.
