Could you also post here a part of the SCADA-Server log file? Let’s check how the server behaves in this period of time.
MikhailModeratorGood. Please post screenshot of a command form (in Administrator), so I can tell you how to send similar commands from scheme.
I’m very glad to read that the system is reliable now.
Anyway in the next version Rapid SCADA engine is totally new, and I hope there will be no more such errors.
I wander how to send command using KpMQTT via the Scheme Editor
Before sending command from schemes, you should check that commands are successfully sent from Administrator. Have you already done that?
MikhailModeratorIn current version you can deploy an extra instance of Rapid SCADA like we do in our cloud solution. Also you should provide ability to poll controllers in parallel. Implementation depends on communication protocols.
Yes, it is. It will support redundancy of data archive.
1. A sending commands form in Administrator is general. Implementation depends on a particular driver. If you already able to successfully send commands using Administrator, I can describe how to do the same from schemes.
2. Is this a string to be parsed? Why do you send different values in a one topic?
Screenshots would help to understand your task.
@jacklondon is right. You should allow incoming connection to the HTTP port 80 on the Windows firewall.
Thank you for the details.
Could you try another approach for the same thing?
Do the following:
1. Make inactive the existing watchdog triggers.
2. Create a new trigger that fires “On channel data change”
3. Create a similar command for the new trigger and tick “Copy value or data” checkbox.
4. Don’t use “Out channel” in the trigger command, but use “Device” and “Command” fields.Please let me know about the result.
Please provide an example what do you get after decoding an incoming BACnet message?
May be I should apply the suggested updates, may be not. To do this I have to be sure that they are really necessary there.
MikhailModeratorMy server is on 192.168.1.60 …. on this server machine if I put 192.168.1.60/scada/ in the search bar of Chrome it all works . If I go onto another PC on my network I can not connect at all …just get a connection time out
Please create a new topic for this question, because it has another sobject.
You can get a list, but you can find a device (KP) by a numerical address or string address (CallNum).Could you explain, how do you detect that an UDP packet is addressed to a particular device (KP)?
MikhailModeratorPlease make screenshots of the related output channels. I need to check their properties, especially formulas.
Try the links below
https://sourceforge.net/projects/modrssim/
https://sourceforge.net/projects/modrssim2/Does at least one of them work?
Please check:
Does the server stop responding in the same moment when Automatic Control Module sends a command? If yes, which output channels numbers related with the problem? -
