MikhailModeratorHello Rich,
I think, you need an extra channel of the calculated discrete type. A formula should check when the source input channel was changed from 0 to 1, then set the 2nd channel to 1 and remember a timestamp. After that compare current time with the timestamp to determine when to change the 2nd channel back to 0.
Formulas must be calculated as fast as possible. Avoid delays, tasks and thread in formulas.
MikhailModeratorLooks amazing! Thanks a lot!
MikhailModeratorApache 2 license allows to create derivative products based on Rapid SCADA. So it’s possible not to show the original name in page titles.
MikhailModeratorRapid Gate 5.1.1.0 requires Server 5.1.4.1. You should update Rapid SCADA to v5.8.2.
MikhailModeratorThe 1st image is good, but the 2nd and the 3rd images does not open. Could you check the links?
Thanks a lot. I will try to reproduce the problem using you project and write here.
Adding 1s delay will reduce the probability / frequency of the server crash, but can not complete solve it.
I mean adding a delay to a command in the module settings, not to request. If delay is added, commands are added to a queue instead of being sent directly. The queue should protect the server app from hanging.
but I have no license of auto control module on my this computer
Get a trial key https://rapidscada.net/trial/TrialKeyGen.aspx
MikhailModeratoras you have already refused to help me run Rapid SCADA on Linux Mint
I don’t. Despite it’s more difficult to configure Rapid SCADA on Linux, Linux has significant benefits:
– No licenses fees;
– Reliability
– Many people just love it.
MikhailModeratorAs a workaround of the hanging problem, I suggest to set delay of the command to 1 instead of 0. In this case command is send using a queue that is more reliable. Let us know about the result.
MikhailModeratorUse a VPN in your browser, which should help you get access to image hosting services
It may be complicated in China. If somebody has experience with that, please share.
MikhailModeratorDo you need help at the moment?
Notification Plugin doesn’t work on Linux (it will be fixed in the future).
Disable the Notification Plugin and restart Apache (or reboot the server).
Is it possible to login Rapid SCADA?
MikhailModeratorI was asking for a screenshot, not XML. I can check the settings if you provide it.
MikhailModeratorThe content being embedded need to be changed to https too.
Yes, because of the browser protection.
Thank you for the details.
Thanks for the recipe.
I am pending if you set up a standard solution for this issue.
There is a update for PostgreSQL connector, but it has a lot of dependencies and it’s better to use it with .NET 5. In the future Rapid SCADA will be ported to .NET 5, and this should solve the problem.
