MikhailModeratorDid you install Chart Pro?
After step 4, there will appear a registration menu item in the web application which contains the code.
– Mqqt what format is supported, can we have our own protocol inside MQQT? Is it possible to send data with timestamp?
Could you explain how to insert other protocol inside MQTT?
– If it’s possible to send data with timestamp, can you send/insert data for the past(like yesterday).
Yes. But MQTT works with current data. You should look for Enron Modbus and OPC UA, for example. Probably, driver update would be required to support reading archive. In general, it’s possible in Rapid SCADA.
– In Rights table I can’t select interface, so that I would assignee user access to interfaces.
Please provide screenshots.
– Can you save data to db just on change?
You can do it using Database export module. In Rapid SCADA v6 we will extend this capability.
– Can you export data from DB to .cvs in selected time frame? Can you append name to data? If I export data from Administrator -> Archive there is just number of the input in input channel.
We can develop a required application by a contract if needed.
– I see that you can access data in archive. Is it possible that data is saved to archive just when value is changed and not every minute?
See above.– Can you edit or delete part of the archive (from date to date)?
You can delete daily data, because every day new file is started.– Can we see how much data is there for each object?
Please clarify.
– What database is Archive using?
Rapid SCADA uses our own engine, no 3rd party DB required. In version 6 we also will support InfluxDB and PostgreSQL.
What you can do to decrease CPU load:
1. Use RAM disk for C:\SCADA\ScadaComm\Log directory.
2. Add this log directory to antivirus exception.
3. Increase delays after request in request sequence or after line cycle.
Please make a screenshot of the command text when you send email.
It is shown in the web form. It’s depends on the plugin, see the manual for details.
What plugin do you mean?
MikhailModeratorOK
Could you make a screenshot of the CPU usage by processes (Task Manager)?
The Channel column is empty in “Device 1” tab. It means that input channels are not bound to the device.
Make sure that the project is uploaded to the server, and Communicator is connected to the Server application.
The module writes log files that are located in C:\SCADA\ScadaServer\Log
Please copy meaningful parts of log files in this topic.
MikhailModeratorGreat!
You should check a report example on Live Demo. But a year step is not supported, max. step is 1 month.
According to the log, your polling rate is about 1 second. It depends on network latency and controller speed.
So you need pulse length at least 2 seconds to detect it stable.
Can you explain the Timeout; Delay; Time ; Period; entries please
Please read this. If something is not clear in the article, ask.
Could you post a part of communication line log here to analyze? It’s in Line Stats
where do I set up the polling rate ?
It’s in Communicator – Communication line – Line Parameters – Request Sequence
MikhailModeratorWhen I try to add rights to the role, in the role tab – there is nothing in the interface Object.
You should press the Refresh button above the table to fill drop down lists of the cells.
Now I have an issue where no users can access the pages, even admin and guest
Please start a new topic to discuss this issue. Provide screenshots of the Roles and Users tables.
