Add new channel inputs and commands
Forum Home › Forums › Understanding the Software › Add new channel inputs and commands
  • #8526
    Jure
    I have managed to install, configure Modbus TCP/IP connection and display data on web page. But now I want to add new input channels and output channels, I can see new data and commands in “Device” view, but when I add it to Input channels it wouldn’t add name for channel or display data on web page.
    Device:
    https://imgur.com/a/HrteTle
    Device properties:
    https://imgur.com/a/lB5l953
    Input channels:
    https://imgur.com/a/ptj7Xu5
    So data can be read, but not added to input channels and latter to web page.
    • This topic was modified 5 years, 8 months ago by Jure.
    #8531
    Jure
    I found out that now no value is displayed. I can still change value trough command, but no holding register value is correctly displayed on web page.
    #8534
    The Channel column is empty in “Device 1” tab. It means that input channels are not bound to the device.
    Make sure that the project is uploaded to the server, and Communicator is connected to the Server application.
    #8538
    Jure
    Thank you, i found out that problem was because I unchecked “Bound to server” in Line parameters.
