Viewing 15 posts - 2,926 through 2,940 (of 6,289 total)
  • in reply to: cunstom page develop #9201
    This example may help.
    in reply to: Signal Relative ID to Fixed ID ? #9200
    Do you mean changing datatype of each element in a group?
    in reply to: Administrator Channel pane on LInux #9199
    The primary ideas are kept the same. API changed.
    in reply to: cunstom page develop #9193
    if there are too many channels there will be an error with HTTP requests with method GET
    How many channels can be requested without error?
    Probably you should split one big request to a set of smaller requests.
    To request channels of a view, the view should be loaded in server part of the web app as you did. But it’s not clear solution.
    Or could we change the method GET to POST?
    Using C# you can develop a plugin that provides any API in comfortable format.
    • This reply was modified 4 years, 11 months ago by Mikhail.
    in reply to: Signal Relative ID to Fixed ID ? #9192
    I was wondering why not use starting adress as the signal id
    Talking about Modbus, starting address can be the same for Coils and Holding Registers, for example.
    I think, we will improve Modbus Template Editor to simplify manual operations.
    in reply to: Administrator Channel pane on LInux #9189
    Currently Rapid SCADA uses Mono on Linux.
    Mono is OK for everything that related to logic processing and web application.
    But Mono GIU apps, like Administrator, work bad on Linux.
    In the next version Rapid SCADA 6 we will use .NET5 instead of Mono Framework, both on Windows and Linux. Administrator on Linux will not work. You should edit projects on Windows workstation and upload them to Linux server.
    If we find a sponsor, we can develop Web Administrator for any platform.
    in reply to: SCADA V6 #9182
    Looks good.
    If it’s not related to the topic subject (version 6), please post such messages to another or new topic.
    in reply to: Signal Relative ID to Fixed ID ? #9181
    Rapid SCADA will support string tag codes instead of numbers in version 6. It will allow to avoid such problem.
    in reply to: IEC61107 Protocol driver #9180
    It’s an English language forum. Messages on all other languages will be deleted. Use forum.rapidscada.ru
    in reply to: Administrator Channel pane on LInux #9179
    Using Administrator on Linux is deprecated and should be avoided. Microsoft killed this path.
    in reply to: 2 or more instances of Rapid SCADA on the same server #9162
    So you successfully installed the services different than the default?
    Important note:
    You need only one ScadaAgentService on the server. I suggest to install it in C:\SCADA\ScadaAgent as usual.
    “Unable to login – Error validating user” and “Unable to create session” for both
    Check that the name of the instances are the same in the agent settings and in the deployment profiles. Also check ScadaAgent.log for error details.
    in reply to: Shared variables #9159
    SetVal(5050, Cmd) should work.
    in reply to: 2 or more instances of Rapid SCADA on the same server #9153
    Hi Matt,
    To be honest, you are the 1st who asked about that non-official feature.
    I can try to fix it via remote connection. But this is a paid service.
    in reply to: Database SQL usage #9150
    May be the new DB export module can help you. But I’m not sure that it’s compatible with your version of Rapid SCADA. And there is no manual for the module. Anyway, let’s try.
    in reply to: Shared variables #9149
    The output channel 5051 neither has “Command number” nor “Formula”. That’s why it does nothing.
    If you want the output channel 5051 to change input channel 5050, you have to use a formula SetVal(5050). And don’t forget to channel input channel type to Calculated discrete/real.
