Viewing 15 posts - 2,776 through 2,790 (of 6,289 total)
  • in reply to: Table editor – Configuration database not found #9690
    You should open Table Editor from Administrator by double click a table in the explorer tree. Then the editor can find the configuration database related to the opened table.
    in reply to: SchemeEditor #9689
    If you question is about Dashboard, you should create a new topic and specify a particular question.
    in reply to: SchemeEditor #9685
    Please tell more about the modified Scheme Editor with align buttons. Where we can download it?
    in reply to: SchemeEditor #9684
    Please check “Scheme Templates” here.
    You could create a 1 scheme, use it as a template, and add 4 views in the Interface table (in Administrator). Then use the Dashboard Plugin to display 4 schemes on a one screen.
    However, we also think about custom scheme components in the future.
    in reply to: Run Rapid SCADA in Microsoft Azure VM #9678
    Nice.
    What VM specifications did you choose?
    in reply to: Com Ports ? #9671
    Hi Rich,
    Thank you for describing the final solution.
    Do you plan to develop a driver for polling data?
    in reply to: OPC UA Driver #9670
    You should open the DLL file properties and unblock the file.
    in reply to: SQL #9667
    Please provide screenshots of the module settings and logs which can be found in C:\SCADA\ScadaServer\Log\ModDbExport_*.log
    in reply to: Have no show Input channel in Table Editer #9665
    This subforum is related to OPC issues, not SQL server. Please create a new topic here providing screenshots and log.
    in reply to: Com Ports ? #9662
    I don’t want to put it onto my live system
    In this case you should develop (or order development) a driver for Rapid SCADA to poll devices using the custom communication protocol.
    in reply to: Run Rapid SCADA in Microsoft Azure VM #9661
    1) I suggest at least Windows 10 or Linux.
    2) You need static IP address.
    3) http://SERVER_IP/scada
    If you register your domain name, you could use address like http://rapidscada.net/scada/
    in reply to: Com Ports ? #9658
    Hi Rich,
    RS-232 is just a communication interface. The most important is how data is encoded when transmitted.
    Do you successfully write values to a text file?
    Does the above formula to retrieve data from text file work?
    in reply to: Export data to SQL #9656
    The new Rapid SCADA 5.8.4 contains fully redesigned Export to Database module. I recommend to update.
    in reply to: Export data to SQL #9652
    Module screenshots and logs appreciated.
    how does the module knows wich channels to export?
    The current version of the module exports all channels. In the next version, a user can specify the channels.
    in reply to: OPC UA Driver #9648
    This error probably means that the driver version is incompatible with Rapid SCADA version.
    Please check Communicator and Administrator versions.
    Full error message would be useful, it can be copied from C:\SCADA\ScadaAdmin\Log\ScadaAdmin.err
