Run Rapid SCADA in Microsoft Azure VM
Forum Home › Forums › Understanding the Software › Run Rapid SCADA in Microsoft Azure VM
  • #9659
    kcks66
    Hi Mikhail,
    My new project is as subject. I am new to Microsoft Azure, I have questions to ask:
    1) Can I create a VM with Windows 7 to run Rapid SCADA?
    2) Is there any specific network setting I must configure in VM in order for me to access Rapid SCADA web from internet?
    3) What URL to use for me to access Rapid SCADA web from internet? I normally use http://localhost/scada to access in my local machine.
    #9661
    1) I suggest at least Windows 10 or Linux.
    2) You need static IP address.
    3) http://SERVER_IP/scada
    If you register your domain name, you could use address like http://rapidscada.net/scada/
    #9677
    kcks66
    Hi Mikhail,
    Thanks for your advice. I managed to setup Rapid SCADA runs in Microsoft Azure VM.
    #9678
    Nice.
    What VM specifications did you choose?
    #9679
    kcks66
    Hi Mikhail,
    Standard B2s (2 vcpus, 4 GiB memory) with add on 128GB HDD
