MikhailModeratorHi everybody,
It would be nice to get user feedback about Zeus’s IEC61850 server here on this forum.
If RTU500 works as IEC 61850 server, you need an OPC server to integrate it with Rapid SCADA.
If you are looking for RTU500 manual, you should request the manufacturer.
MikhailModerator@dateTime should be in the SQL request. Actually, there is @dataTime
MikhailModeratorYou right, we are going to improve error messages.
MikhailModeratorSchemes use Chart Pro inside a frame.
> But the font is really blurry
What monitor resolution and scaling do you use?
What browser?
Text is rendered by JavaScript on canvas, may be some parameter can affect it.
Interesting idea. I will think about it.January 12, 2022 at 11:18 am in reply to: After the custom unit is wrong, it cannot be modified #9906
MikhailModerator> The sign field is the unit displayed in the scheme, right?
That’s right.
The module writes log files into C:\SCADA\ScadaServer\Log
Please check if there are errors in logs.
MikhailModeratorCurrently, you can also select components from a drop down list of the editor. If you provide friendly names to components, you can easily find them in the list.
> Instead of “your not allowed to open this”
Do you mean errors when a user opens a view?
MikhailModeratorThe chart component has the Background color property. But chart uses its own settings loaded from PlgChartPro.xml. You should find this file in your project and change properties in the XML file. You can create many XML files with different chart properties and use a particular file.
Am I understand correctly that you are talking about displaying the same scheme (*.sch) in different languages?
January 11, 2022 at 11:37 am in reply to: After the custom unit is wrong, it cannot be modified #9889
MikhailModeratorPlease provide screenshots of the error and a sequence of steps to reproduce the error.
May be you should refresh the Input channels table before using new units.
MikhailModeratorAll files should be located inside the project: C:\SCADA\Projects\YOUR_PROJECT
MikhailModeratorYou need 45 output channels. Which XML file do you mean? Probably, you don’t need any special XML file.
> Would it be at all possible to add a new property for buttons and links?
It’s a good idea which allows to use less channels. I’ve added it to the backlog.
Webpage view shows an external page. How do you mean it should work?
