background color of the chart
Forum Home Forums Understanding the Software background color of the chart
  • #9897
    grhsc
    I set the background color of the chart and trend in the editing interface, but after running, I found that the background of the chart is still white. I am sure that it has been saved, forced to refresh, and logged in again.
    https://drive.google.com/file/d/1zI0BjghjL8wUhva7Og6tB4TypAWxpDkQ/view?usp=sharing
    https://drive.google.com/file/d/1AStKRIx6yzqcghrOHkdV98daRCQmrbZQ/view?usp=sharing
    • This topic was modified 4 years, 3 months ago by grhsc.
    #9900
    The chart component has the Background color property. But chart uses its own settings loaded from PlgChartPro.xml. You should find this file in your project and change properties in the XML file. You can create many XML files with different chart properties and use a particular file.
    #9904
    grhsc
    thank you,
    Sorry I may not have described clearly, it is not chart pro, but chart in Extra Scheme Components.
    Also, I found that the chart pro Components seems unclear, a little vague, is it the reason for the size and settings?
    2 type chart questions, sorry for confusing you
    as below
    https://drive.google.com/file/d/18vgheBRPArofqCLjEb__N632x1_mWJjt/view?usp=sharing
    • This reply was modified 4 years, 3 months ago by grhsc.
    #9908
    grhsc
    Thank you very much, by customizing different xml I have got what I want.
    But the font is really blurry, I tried adjusting to 14, still the same
    #9910
    Schemes use Chart Pro inside a frame.
    What monitor resolution and scaling do you use?
    What browser?
    Text is rendered by JavaScript on canvas, may be some parameter can affect it.
