Viewing 15 posts - 2,521 through 2,535 (of 6,289 total)
  • in reply to: Chartpro Plugin #10439
    Creating a web page view does not require any programming. Just add a row in the Interface table.
    Can we define for each individual parameter different axis
    PlgChartPro.xml is a correct file name.
    An individual axis for each channel is possible only if all channels has different quantities. Because an axis is chosen for a channel according to its quantity.
    in reply to: Rapid SCADA 6 Beta #10438
    Is there a solution to this problem on V5?
    The issue is solved in the v6.
    In the meantime, I suggest adding a column for “ratio”
    Creating a function Ratio that makes linear calculation may be more clear. For example, channel formula would be
    Ratio(0.5, 10)
    in reply to: Chartpro Plugin #10434
    1. You can add a web page view to show a chart with predefined channels.
    This is an example how to add a web page view.
    Also I suggest to use Dashboard Plugin to easily display different charts.
    2. In Chart Pro configuration file (ChartPro.xml) you can define several Y-axes. Channels are bound to an Y-axis according to the channel quantity that should match the QuantityIDs parameter of the Y-axis.
    If you have questions during the implementation, please provide screenshots of the settings and results.
    • This reply was modified 3 years, 11 months ago by Mikhail.
    in reply to: Rapid SCADA 6 Beta #10430
    Channel data type should match datatype of a driver tag. The Modbus driver uses the double type for all tags.
    64bit integer data type may be useful for long counters, because its max value is bigger than double.
    When I use “ export… ” to export channels to CSV files, and I have a coding problem If I use simplified Chinese in channel names
    Please create a separate topic to discuss this issue in details and fix.
    If you need a new simplified Chinese language pack, I’d be glad to do it.
    That would help the project very much. Currently the phrases continue changing. After we release a stable 6th version, simplified Chinese translation would be appreciated.
    in reply to: How To Set Alarm Continuously #10429
    You could use a hardware relay. So you can play alarm signal independently from web browser.
    Also you need a calculated channel that indicates that alarm is active. Automatic Control Module would send commands to control a relay depending on the channel value.
    in reply to: Rapid SCADA 6 Beta #10426
    The Rapid SCADA 6 Beta 8 update has been released. The download link is at the beginning of the topic.
    What’s new:
    – Fixed bugs found in various applications and modules.
    – Added options for table views, which, among other things, allow to set the displayed archive for a particular view.
    – Added an archive option for the standard Chart Plugin. For example, in the address bar add …&archive=Hour
    – The format description is displayed on the command sending form, if the format is string.
    – The logic of Rapid Gate Module developed. The user interface of the module is partially ready.
    in reply to: how to send a modbus value #10423
    How do I send a float value to the device?
    Usually writing a float requires 0x10 Modbus function. Set the Multiple checkbox, specify data type, and try sending command without any formula.
    If something goes wrong, provide logs and screenshots.
    in reply to: Want to Control Input Data Overflow #10421
    Channel(101) > 65525 then it shows -1 otherwise it shows the actual value
    Use the formula for the channel 101:
    Cnl > 65525 ? -1 : Cnl
    How can we use custom Formulas in Rapid Scada
    Check this article https://rapidscada.net/doc/content/latest/en/software-configuration/using-formulas.html
    in reply to: Want to Control Input Data Overflow #10418
    Do you need to display 65526 as -1?
    in reply to: Does ScadaComm not support win32 programs? #10417
    Driver should be developed using .NET Framework. See the article for the details https://rapidscada.org/device-drivers-development/
    in reply to: AllenBradley PLC Polling Driver (Ethernet) #10411
    in reply to: ModDbExport Questions #10410
    What useful info is available in the module log files?
    in reply to: Installation Issue on Elastic Report #10407
    in reply to: Installation Issue on Elastic Report #10405
    …@ElasticRep
    in reply to: Installation Issue on Elastic Report #10404
    You have to define the view type in the Views table as shown here https://rapidscada.net/doc/content/latest/en/modules/plg-elastic-report-files/report_itf_tbl_en.png
