October 18, 2022 at 9:04 am in reply to: Notification plug in (trial key vs paid registration key) #11304
Notification Plugin requires to acknowledge all alarm events to stop bell ringing. It’s also possible to disable sound by the mute button.
MikhailModeratorWe do fix critical errors in version 5. All new features and minor improvements will be included in version 6. This issue is not critical.
MikhailModeratorJust a little worried because no confirmation after back connected.
It would be good to improve logging.
found it the printer icon move down
Fixed. Will be included in the next release. Thank you.
Telegram Driver instructions are here.
In case of particular questions, ask on this forum.
MikhailModeratorChanging winehq-devel to winehq-staging works.
MikhailModeratorAfter adding ScadaInstanceConfig.xml to the proper location, got another error https://ibb.co/6F077VL
ScadaAdmin.log doesn’t contain any error.
MikhailModeratorI use also Ubuntu 20.04 and wine 7.18.
To check the version usewine --version
Simple WinForms app works correctly. But ScadaAdmin does not. Did you update solution or other ScadaAdmin files before publish?
MikhailModeratorWhich Ubuntu and Wine version do you use?
MikhailModeratorTrying to run ScadaAdmin with Wine, faced the error https://ibb.co/LQNcD2B when execute
WINEDEBUG=+loaddll wine ScadaAdmin.exeWine installed successfully. ScadaAdmin published also without any error.
I use the current source code from https://github.com/RapidScada/scada-v6
Do you have any idea what should be checked and fixed?
MikhailModeratorWhile Server is restarting, connection errors in Communicator is a normal situation. Communicator reconnects when it’s possible.
In the module configuration you should add triggers for data export.
MikhailModeratorI recommend Telegram notifications instead of emails.
MikhailModerator
MikhailModeratorI’ve used the method provided by Alexander of Macedon and deleted .NET4.8 services.
