Viewing 15 posts - 2,026 through 2,040 (of 6,279 total)
  • in reply to: config fie upload #11993
    Weird. What is written in Agent settings and log?
    in reply to: V6 – Extra Scheme Components #11992
    Thank you for finding this bug.
    Please download and update the plugin again. Now it should work in Scheme Editor also.
    Note: plugin registration is not needed for editing schemes.
    in reply to: Elastic report V6 download link #11985
    It’s possible. Click Main Menu – Reports -…
    in reply to: config fie upload #11983
    If you delete the existing configuration files, is possible to upload new configuration?
    in reply to: V6 – Extra Scheme Components #11982
    You should update Rapid SCADA to version 6.0.1 to use the components.
    in reply to: Elastic report V6 download link #11979
    Elastic Report has not been ported to v6 yet. Work status is here.
    in reply to: config fie upload #11976
    What error do you get? Could you provide a log?
    Could you make a screenshot of the file and directory permissions and owner?
    in reply to: The login page of the web always prompts an error #11975
    in reply to: what is chart profile? #11971
    Chart profile has a name and contains chart options. The list of profiles is defined in PlgChartPro_Config.xml
    To define a group of trends, you can specify a chart view in the Views table. For example, https://ibb.co/m46125b
    in reply to: V6 – Extra Scheme Components #11970
    Approximately, 1 or 2 weeks. The link will appear on this page.
    in reply to: SMS GSM Cinterion Modem #11969
    Modem should be Siemens C35 compatible.
    For example, we successfully used Huawei E1750
    in reply to: The login page of the web always prompts an error #11968
    What parameter we need to change in the app pool options?
    in reply to: Implementation of “Per Console” permissions #11960
    Hi Louis,
    According to my understanding, the possible architecture is as follows:
    1. Each location is served by a separate Rapid SCADA instance.
    2. We can have the central Rapid SCADA instance on the main server that collects primary data from locations. Or don’t have central SCADA, so the system can be decentralized.
    3. There is a special module, named Rapid Gate, that transfers data between Rapid SCADA instances in the specified directions.
    4. User management can be implemented either by the built-in Rapid SCADA features, or by using an external auth system.
    Please ask related questions to clarify the possibilities of a solution.
    Note: what do you mean by “console”?
    in reply to: SMS GSM Cinterion Modem #11958
    May be you should try to find utilities that send AT commands to modem and test them.
    in reply to: SMS GSM Cinterion Modem #11957
    Dear Han,
    Something wrong in SMS packet. To find a cause, it’s needed to learn SIM808 documentation and make a research. Such work is not included in support.
    I recommend to use Telegram to send notifications. Or use special REST web services.
