Viewing 15 posts - 1,921 through 1,935 (of 6,279 total)
  • in reply to: Export data to XML #12273
    If you use PostgreSQL archive that is configured on Server – Archives form in the Administrator app, database tables are created automatically. You can define archive mask for channels to store only required channels. To get channel properties and other entities in the database, configure a deployment profile based on PostgreSQL, and upload the configuration database to PostgreSQL.
    If you need to use your own database model, you should choose Export to DB module with the supported database (PostgreSQL, MySQL, MSSQL or Oracle). The available variables are specified on the module configuration form.
    I think, your Chart Pro installation is up to date.
    If you don’t mind, can I provide teamview for your access?
    Yes, it would be very helpful. This Wednesday works for me. Please email connection details to info@…
    The up to date version of Chart Pro is 6.0.0.1 released on January 17, 2023.
    Webstation version is 6.0.0.1 released on January 17, 2023.
    General Rapid SCADA version is 6.0.2 released on February 20, 2023.
    What ChartPro version is installed?
    Can’t reproduce the issue on my machine, unfortunately. Is it possible to provide HTTP access to the web application to be able to open a chart over the internet?
    in reply to: не отображается в браузере #12265
    This forum is in English. For using Russian, please write on https://forum.rapidscada.ru/
    in reply to: MQTT not reading messages #12263
    Line State – Undefined status is a minor bug. Thank you that you found it. Will be fixed in the next release.
    Try another broker that works for me: https://ibb.co/yn2w488
    in reply to: MQTT not reading messages #12260
    You should choose “MQTT Client” for a device, not “MQTT”.
    MQTT Client is the new driver for v6.
    Don’t forget to set Communication Channel = MQTT client in the line options.
    In case of issues, please provide links to screenshots of your settings and errors.
    in reply to: Export data to XML #12258
    And my last question
    Ask as many questions as needed.
    in reply to: Export data to XML #12257
    PostgreSQL is the main DBMS for Rapid SCADA. Therefore, there are special features for this database.
    in reply to: Export data to XML #12256
    You should create your own stored procedures that fill code and name and use them in the Export to DB module. However, it is not optimal.
    In case of using PostgreSQL, you can upload the project to the database, so you can find channel code and name by its ID.
    in reply to: формат float ieee-754? #12255
    in reply to: Installation problem RapidScada 5 #12254
    For some reason, the services were not registered in OS. You should register them manually by executing the items 7-9 from the manual.
    in reply to: Elastic Report #12249
    Elastic Report supports multiple sections of the same type in a report.
    You should check the error details in ScadaWeb.log
    I will try to use the available information. If that’s not enough, I’ll ask.
