May 23, 2023 at 10:17 am in reply to: Server Slient Crash – ScadaServer killed by OOM killer on Linux #12686
Some thoughts:
– Server v5 requires a lot of RAM when trends (charts) are requested by a user.
– Is it possible to check what amount of RAM was consumed by the Server service when it was killed?
– 218 MB of free memory is not big. If possible, add memory to the server.
– Rapid SCADA 6 uses systemd daemons. Consider moving to v6 in the future.
MikhailModeratorWhen a device is disconnected, channel status = 0. You should also store status in the database, or use status to convert values to NULL if status is zero.
There are 2 independent tasks:
1. Get data from OPC DA.
2. Provide data as OPC UA. Rapid SCADA 6 is needed for this.To solve the 1st task, use usual configuring sequence, as written above. In case of errors, please provide screenshots of the settings and logs.
After the 1st task is done, ask about the 2nd,
Do you mean displaying data on a map permanently? Could you draw an example?
In the connection options of the Communicator B you should specify the Server A.
It would be more efficient if you provide screenshots of your settings.
API provides access to channel data by channel numbers. Channel names are not unique, so cannot be used to get data.Getting channel data using REST API by some unique string codes can be a good idea for the future improvements. Currently, you need an internal dictionary that provides channel number by its name or code.
I think, you need 4 instances in the project:
– Default
– Remote1
– Remote2
– Remote3The instances are declared in the project, and deployed on different machines.
MikhailModeratorAlso check in log files that data queues of the module do not overflow.
MikhailModeratorIn Rapid SCADA all data uses UTC timestamps. Some databases (like PostgreSQL) have special data type to work with timezone, some databases don’t have such data type.
If actual timestamps always differs by timezone offset, it’s OK and can be corrected in the SQL request.
I recommend use the same Tag Code and Topic parameters.
You don’t need to create commands under the Command node.
If a subscription is created and not read only, a value can be published.
MikhailModeratorI suggest trying broker.mqtt-dashboard.com for testing.
MikhailModeratorCould you tell what is “BBDD”?
What is the time zone?
MikhailModeratorCan’t find a screenshot where the
Optionsnode is selected.
Could you add a screenshots of Device 4 Properties – Options?
If you try the same on public broker broker.mqtt-dashboard.com, does it work or not?
Currently, the MQTT driver doesn’t support strings. It’s possible to implement in the future.
Strings are supported by OPC UA driver, for example. -
