The default user name and password are listed in this article. If you change the defaults, please provide screenshots of the new settings and log files.
Does this issue occur when you upload the HelloWorld project?
Is that folder completely deleted?September 30, 2024 at 11:39 am in reply to: rapidscada v6.1 opcDA SourceCode (DrvOpcClassic.Logic) #15508
No. The request format should be as you posted.
We just want to have daily backup in easily accessible format.
Good idea. It can be used in a combination with other backup methods.
will there be any changes in script to convert while generating data?
There are no such plans. We might add a time zone option for a fee.
I would like to understand for what purposes you export data to CSV?
> My understanding is to have it in XLSX format I need Elastic addon?
XML format of the reports is Office XML 2003 that can be opened by Excel and Libre Office.
Elastic Report can generate reports in XLSX format.
I hope we will support XLSX for the default reports someday.
Set Data type to empty for all channels except 103.
Set Format for the channel 102
MikhailModeratorPlease create a corresponding topic to discuss DrvMqttPublisher.
MikhailModeratorIn case of concerns, provide screenshots of the AutoReport settings.
As there is no video or detailed manual for Auto Report installation I have stuck on testing it on version 6.
Feel free to ask here. I hope we will create videos to cover the most of questions in the future.
Create a device and an output channel to send and receive commands for generating reports.
It’s not needed. AutoReport is a separate service that has it’s own schedule to run reporting tasks.
This reply was modified 1 year, 8 months ago by
MikhailModeratorWere you able to obtain the data using the bit number?
MikhailModeratorData polling seems OK.
I recommend:
1. Use Rapid SCADA 6, because Rapid SCADA 5 is outdated.
2. Provide names for the elements in the Modbus template.
3. Create a simple table view to check data displaying. Then create a scheme view.
MikhailModeratorYes.
