MikhailModerator
MikhailModeratorDo you have any idea about http://forum.rapidscada.org/?topic=new-web-app-idea ?
This checkbox works for command triggers only.
The feature of inserting dynamic text is not supported by Auto control module for now. It is in the plans.The specified feature will be possible when the module can send command via output channels. In this case using a formula you could generate any text.
May 17, 2016 at 6:48 am in reply to: "Application Error: Unable to Load View" Error Windows 10 #1188
MikhailModeratorThank you 🙂
This is not a bug. The directory of the view set must be correct. It can be set by SCADA-Web Configurator. I’m used edit files.
MikhailModeratorI will check.
Is there any additional info in C:\SCADA\ScadaAdmin\ScadaAdmin.err ?
MikhailModeratorI’m sorry to say that I don’t agree with your decision on keeping with binary data but… OK.
May be the source code should be refactored to allow switching the storage.
MikhailModeratorWhich parameter controls this?
SCADA-Server -> Minute data -> writing period
May 16, 2016 at 6:19 am in reply to: "Application Error: Unable to Load View" Error Windows 10 #1180
MikhailModeratorYou have to specify
<ViewSet name=”Home Meters” directory=”Servers\”>May 15, 2016 at 7:18 am in reply to: "Application Error: Unable to Load View" Error Windows 10 #1175
What are the current full paths of your *.tbl on the disk?
Also post here a content of C:\SCADA\ScadaWeb\config\ViewSettings.xml
MikhailModeratorAs for me, at my previous work I switched from .NET to Java EE. The ideas and approached of these platforms are more similar than different. For now, development moves to client programming, I mean HTML, JavaScript and CSS, those are vendor independent, and this trend makes me happy ))
If you decide to join Rapid SCADA development, I’ll help you to start and understand the concept of the project classes.
MikhailModeratorIt is possible to develop the appropriate driver but it may be expensive depending on the project budget.
If I understand you correctly, you need Rapid SCADA works as slave and your RTU as master. This mode is not supported for now, unfortunately.You should use another architecture of your system. As an option, you can use DBMS for integration or request your device by Rapid SCADA and by RTU in parallel.
MikhailModerator– Could we configure it to 1 plot-point each minute instead of 2?
Please, explain what do you mean?
Thank you for the useful research.
The approach of using binary data format has several advantages:
– It is optimized and can be improved to provide very fast access.
– Doesn’t depend in 3rd party software => easy to install and backupSo, I have no plans of moving to RDBMS.
Or improve performance/method access to .DAT files…
I agree. This work is permanent. For example, the new web app has modern cache to allow multiple users access data faster.
30-days 10-chnnels chart contains 24*60*30*10 = 432000 points. It is not a few.
May be the bottle neck is drawing these points.Could you generate similar Excel report and compare the duration?
It would be interesting to compare with other JavaScript charts such as http://www.highcharts.com in conjunction with MySQL or PostgreSQL (like here).If you could continue the research, it would be wonderfull 🙂
