ModAutoControl: send email with channel values
Forum Home › Forums › Development and Integration › ModAutoControl: send email with channel values
  • #1189
    inpelsa
    How can I include on the email’s subject/body specific/any channel’s values?
    Which are the requirements to be “Copy command value or data” checkbox to be enabled? (in case this is what I need)
    Thanks,
    #1190
    This checkbox works for command triggers only.
    The feature of inserting dynamic text is not supported by Auto control module for now. It is in the plans.
    The specified feature will be possible when the module can send command via output channels. In this case using a formula you could generate any text.
    #1192
    inpelsa
    Ok I understand, just as a suggerence:
    Receiving detected value could be a VERY good thing: It really helps a lot to receive the value and see value is just 1 unit above specified… or 1000 units!
    Adding several triggers for different ‘levels’ for several channels is… unfeasible.
    If adding full dynamic text support takes too long or is complex, think about an easy shortcut: just replace “[CNL]” text on the binary string or a checkbox like “add value at the end”.
