MikhailModeratorPlease create A NEW TOPIC:
1. Go to this subforum
2. Scroll the page down and find a text Create New Topic in “Installation Issues”
3. Describe your issue in details, including links to screenshots.
4. Press Submit button.
MikhailModeratorColumns just change their display names, but were not changed in the database ))
MikhailModeratorSorry, my advice was not fully correct.
You can manually install Webstation into C:\SCADA\ScadaWeb5 and give a name Scada5 for the website.
Use this manual in the part describes web app installation.March 3, 2017 at 12:43 pm in reply to: Comunication with Siemens Plcs via Profinet or Ethernet #1980March 3, 2017 at 5:54 am in reply to: How to get the data which automatically sent by the devices? #1978
MikhailModeratorPlease create a new topic and provide more details.
MikhailModeratorYou can save all the data.
It is possible to upgrade softly:
1. Install only the new web application using other virtual path name.
2. Specify the views into the configuration database as written in the current version of manual.
The current version of Chart Pro plugin is compatible with Rapid SCADA 5.
I highly recommend you to update Rapid SCADA to the new version.
MikhailModeratorIf it doesn’t help, please, press F12 in browser, do screenshot of Console tab and provide a link to the screenshot.
MikhailModerator
Because devices are not connected to your server. You can use Modbus simulator and OPC simulator as shown in YouTube videos.
MikhailModerator
MikhailModeratorWe found out the cause: port 10000 was used by another application.
MikhailModeratorI’ve sent you an email.
MikhailModeratorCan you connect to SCADA-Server using Hercules utility?
MikhailModeratorYou have to add a new record to the Rights table that contains “Servers\” interface object and “Teste” role.
