Data are read from an archive, when the web interface requests the data. So new data will be displayed when a view page or chart page is refreshed.
To indicate whether a command is processed successfully, a device should write some data into the device tag.
MikhailModeratorBy default, the utility uses the old path. It should be updated someday.
Thank you for the information. That means that the plugins should be improved in the future.
MikhailModeratorPlease make a screenshot of the C:\SCADA\Archive directory that is used in your screenshot.
Thanks a lot for the update.
MikhailModerator> Not sure if there are rules for file sharing links on this forum (I did not find a policy)
Links are allowed if they are on-topic, excluding links to other SCADA.
> Will upgrading to Rapid SCADA 6 from version 5 affect the registration key that I bought for version 5?
Yes. We will update the keys for free for the same computer.
You can install v5 and v6 in parallel using different TCP ports for Server and Agent.
> Elastic report can configure to show full text?
Could you try that using a trial key?Historical data report should be updated to support long strings.
For now, may be you can put channels containing text parts into different Excel cells, and then join them manually.
1. The PlgChartPro.xml file contains the plugin configuration. It should be copied into the project.
2. Upgrade to Rapid SCADA 6 from version 5.
Try using a historical data report for that purpose.
It makes no sense to display string values on graphs.
Please clarify to whom the question is addressed.
I suggest also test in a table view.
The above advice should work.
If a channel has a length = 5, it is internally 5 channels. A formula is executed for each of them.
MikhailModeratorIt would be useful to develop an OPC UA server for Rapid SCADA on the level of the Server service (in addition to the existing OPC UA server for Communicator), so it can provide calculated values.
While waiting for the example, this video about Modbus may be useful. -
