Get Application Error when use “Chang period”
Forum Home › Forums › Runtime Bugs › Get Application Error when use “Chang period”
  • #16455
    yadapa
    Hello.
    I got this error message when I clicked ‘Change period’ on the chart page:
    Application Error
    Details:
    Value cannot be null.
    Parameter name: key
    Additional Info:
    When I go to the chart page, this message appears in the upper right corner:
    >>> Error loading Chart Pro plugin configuration: File C:\SCADA\ScadaWeb\config\PlgChartPro.xml not found.
    After some time, this message appears:
    >>> Generated 09/06/2025 10:02:48
    Although the message in the Additional Info had appeared previously, I was still able to use the ‘Change period’ function — but now it no longer works.
    #16462
    1. The PlgChartPro.xml file contains the plugin configuration. It should be copied into the project.
    2. Upgrade to Rapid SCADA 6 from version 5.
    #16465
    yadapa
    Hi Mikhail
    Thank you for your reply.
    Will upgrading to Rapid SCADA 6 from version 5 affect the registration key that I bought for version 5?
    #16466
    You will need to re-request the keys for version 6 on the same PC.
    • This reply was modified 1 year, 4 months ago by manjey73.
    #16472
    Yes. We will update the keys for free for the same computer.
    You can install v5 and v6 in parallel using different TCP ports for Server and Agent.
