Viewing 15 posts - 346 through 360 (of 6,270 total)
  • in reply to: Manual for Rapid Scada v 6.4 #17029
    The manual exists as an interactive website. There is no PDF document. It’s possible to copy all the web pages into a DOC file and save as PDF.
    in reply to: Map Plugin question #17028
    Check ScadaWeb.log. Make sure that PlgMap is loaded without errors when the web application starts.
    in reply to: Roles for map view #17027
    It is impossible to implement such a possibility this year, but it would be good to implement it. If you remind me in January, there is a chance that it will be done.
    in reply to: CurData in dasboard view #17026
    Please check this example.
    in reply to: Dashboard layouts #17016
    Try playing with the columnWidth attribute. It can help to make rows different heights. For example, two widgets with columnWidth=6.
    • This reply was modified 8 months, 4 weeks ago by Mikhail.
    in reply to: Dashboard layouts #17015
    Currently, no. The aspect ratio is set for a dashboard, so width/height is the same for all widgets. I’ve added this issue to the backlog. If a row has less widgets, its height will be bigger, because the aspect ratio is a constant.
    Nesting is not planned.
    in reply to: CurData in dasboard view #17013
    No, because it is designed for historical data.
    If you familiar with HTML and JavaScript, it’s possible to make a custom page and insert it in a dashboard.
    in reply to: Map location icon #17010
    For example,
        <Location>
          <Name>Eiffel Tower</Name>
          <Descr>Avenue Anatole France, Paris, France</Descr>
          <Icon></Icon>
          <Lat>48.858222</Lat>
          <Lon>2.2945</Lon>
          <StatusCnlNum>104</StatusCnlNum>
          <DataItems>
            <DataItem cnlNum="101" />
            <DataItem cnlNum="105">My text</DataItem>
          </DataItems>
          <Links>
            <Link viewID="2" />
            <Link viewID="2">My link</Link>
          </Links>
        </Location>
    in reply to: Map location icon #17009
    You can see it in Live Demo.
    Blue marker is unbound, while green (or red) marker is bound to a channel.
    Yes, a channel is needed to define marker status.
    in reply to: Roles for map view #17008
    Currently, a map view does not check access rights for each particular object.
    Could you describe how your system is used? I’d like to imagine this case.
    in reply to: CurData in dasboard view #17007
    The CurData widget can only display data as it is. This could be an idea for future development.
    You could insert a table view as a widget if it solves the issue.
    in reply to: Build Rapid SCADA on ARM64 Windows Machine #17006
    I suppose, it should be possible to configure.
    Could you check if AspNetCoreModuleV2 exists?
    in reply to: Update new mimic plugins #17005
    Fixed picture conditions.
    in reply to: Build Rapid SCADA on ARM64 Windows Machine #16999
    Thank you for the info.
    If you open http://localhost on the ARM64 Windows machine, what do you get?
    in reply to: “IF” Formula in channels #16998
    Cnl(101) is a mistake, use Val(101).
