Dashboard layouts
Forum Home Forums Understanding the Software Dashboard layouts
  • #17012
    oley
    Is it possible to set different row heights in dashboard view:
     _______ _______ _______
    | View  |CurData| View  |
    |_______|_______|_______|
    | Chart | Chart | Chart |
    or nesting https://getbootstrap.com/docs/5.3/layout/grid/#nesting
    |       |_______|_______|
    |       | Chart | Chart |
    • This topic was modified 10 months ago by Mikhail.
    #17015
    Currently, no. The aspect ratio is set for a dashboard, so width/height is the same for all widgets. I’ve added this issue to the backlog. If a row has less widgets, its height will be bigger, because the aspect ratio is a constant.
    Nesting is not planned.
    #17016
    Try playing with the columnWidth attribute. It can help to make rows different heights. For example, two widgets with columnWidth=6.
    • This reply was modified 10 months ago by Mikhail.
